Emissions Control
Old Nov 25, 2006 | 08:06 AM
DRocky's Avatar
DRocky
Emissions Control
I can't ssem to find the problem with my 2000 Expy, 4.6L v8. I'm getting a error code of PO400, which indicates "Insufficient air flow - EGR valve". I've replaced the EGR, I've replaced the DPFE sensor, I've cleaned the Trottle Body, I've cleaned the EGR pipe. Any ideas?
Old Nov 25, 2006 | 08:18 AM
projectSHO89's Avatar
projectSHO89
Vacuum test the system.
Engine at idle. Disconnect the vacuum line at the EGR valve. Using a short length of hose, connect it to the EGR valve and suck on it. A properly operating valve with clear ports will cause the engine to stumble or die. If it doesn't, remove the throttle body and clean the gummed out carbon from the ports.
EGR valves seldom fail.
Go to the Full-text TSBs at the top of the page and run a SEARCH on your fault code. You'll be surprised on how much dealer data is already here.
Steve
TXE150
Jan 3, 2015 06:10 PM
Steadyman321
Mar 18, 2013 07:33 PM
AtoJ
Oct 28, 2006 07:51 AM
hboswell
1983 - 2012 Ranger & B-Series
Jan 8, 2004 10:16 AM
Keith460
Jan 15, 2001 01:35 PM
