Common leak
Old Nov 26, 2006 | 08:45 AM
PLC7.3's Avatar
PLC7.3
As stated above Ford/IH does not use a gasket......just the highest quality sealant. A lot of the leaks come from the two front corners on the pan or where it goes under the front seal as usually not enough sealant is used or the wrong type.
Old Nov 26, 2006 | 08:50 AM
bluthunder's Avatar
bluthunder
i call it continuous undercoating
Old Nov 26, 2006 | 09:07 AM
dieselbogging's Avatar
dieselbogging
Then that explains why i had such a tough time to get the pan loose.
Old Nov 26, 2006 | 11:35 AM
93_E_350's Avatar
93_E_350
The PO of my truck parked mine on grass, that and the road salt used during winter turned my pan into a better oil filter than holder of oil . I guess the pan rusting out is pretty common in the northern climates? I would clean and paint it with a good rust preventing paint as a maintenance item.
Old Nov 26, 2006 | 11:46 AM
KJLYPW's Avatar
KJLYPW
I also had a small persistant leak at the front of the engine, thought it was front seal, but it turned out to be an easy fix- the top waterpump bolts were loose enough to pass oil from the timing gear cover. A little RTV and retorque cleaned up the problem.
Old Nov 26, 2006 | 06:46 PM
dieselbogging
i forgot to mention that there was a small crack on the top of my oil pan and amazingly that was the cleanest spot on the pan. i put a little bit extra silicone on it and on the outside i put some muffler cement on. It hardens with heat and it seems to still be holding. If i have to ill touch it with the mig welder.
ehask71
Nov 18, 2016 08:40 AM
DieselCamper
6.4L Power Stroke Diesel
May 30, 2016 07:55 AM
dgulledge
Nov 9, 2014 05:27 PM
Jared32676
1997 - 2003 F150
Apr 16, 2014 07:44 PM
windsor94
Jul 27, 2008 01:47 AM
