If it is the sparkplug does it get louder with exceleration
You should have no problem locating a loose spark plug
that's making noise
Common area for exhaust leaks are due to broken
manifold studs as ,bg7 mentioned, rear passenger side
Easiest seen from wheel well.
good luck and keep us posted
