1978 - 1996 Big Bronco
Power window
Old Nov 23, 2006 | 10:33 AM
mblayton's Avatar
mblayton
Power window
My passenger power window on my Bronco jumps when going up and never closes al the way without help, seems to go down fine, is it the window motors gear shot? would like to know before tearing it apart. Thanks
Old Jan 14, 2007 | 10:00 AM
lljanek's Avatar
lljanek
my 92 is doing the same except it wont roll up at all (without assistance). I'm leaning toward the same solution as you are but checking the forum just to be certain! Like you said...gear might be missing a tooth/teeth.
Old Jan 14, 2007 | 02:28 PM
460srule's Avatar
460srule
I like to try the easiest fix first.Cleaning and some grease may be solution.
Old Jan 14, 2007 | 02:53 PM
dhepler's Avatar
dhepler
motor gear lost some teeth
Old Jan 15, 2007 | 12:13 PM
87hurricane's Avatar
87hurricane
I'd be willing to bet that the little cylindrical spacers in the main gear are shot, really easy to repair, I made some new ones out of a wooden dowel rod. You'll need to pull the window motor no matter what, I'd pull it and find out whats wrong before you spend big bucks on a new window motor that you don't really need.
Old Feb 11, 2007 | 09:18 AM
lljanek's Avatar
lljanek
i pulled my motor, replaced the bushings and gear, now the motor doesn't actuate. that's after i reinstalled it! what the @#%* happened to the motor between pulling it replacing the bushings and reinstalling it? not to mention that my window is stuck half way down! now i have to remove the motor, pull the window up, reinstall it, wait until monday, buy a new motor, just to do it all over again! Gotta love it!
wagoner
2015 - 2020 F150
Oct 28, 2016 11:53 AM
12valveEx
Sep 12, 2016 01:29 PM
pdqtimetrialer
Jul 7, 2016 04:44 PM
teamlx88
May 21, 2015 08:30 AM
tndiesel
Oct 24, 2008 09:46 AM
