power window failure
Old Oct 23, 2008 | 02:55 PM
tndiesel's Avatar
tndiesel
My rear passenger power window will not go up? I haven't got into yet because I wanted to get advice from y'all first.
Thanks!
Old Oct 23, 2008 | 03:17 PM
Hussler's Avatar
Hussler
From which control? Rear passenger control or drivers master control or both?
Old Oct 23, 2008 | 03:21 PM
Cuda_jim's Avatar
Cuda_jim
Been there done that. On mine the window regulator gear stripped out. The regulator is not available unless you go to a bone yard. That one will wear out too. If you find a new one on the internet it will be the wrong one....I've bought new from 2 different places. They send you the front door regulator.
End of rant
I hope you have a bad motor, at least you can get one of those.
You can smack the door while someone holds the button. Maybe it will roll up one last time so your truck is sealed up.
Who ever placed the window button at knee level should be...well you know LOL
Old Oct 23, 2008 | 03:26 PM
tndiesel's Avatar
tndiesel
It won't work from either control
Old Oct 23, 2008 | 03:40 PM
93f1505.0L's Avatar
93f1505.0L
Do you here the motor run? If so try helping it up and see what happens. I cant explain it very well but the window gear has a gear has little rubber ***** in it to take the shock when the motor starts to move. They ware out and you can get a kit for it. I just take 1/4 in nuts and wrap electrical tape around them and put them in the place of the ruber *****. Basically you need to tare into it and see what you find.
Old Oct 23, 2008 | 03:51 PM
ron86toy's Avatar
ron86toy
Mine had same problem.....pull the rear door panel....with a test light and friend test your switches first.....mine was the motor...I hate dealing with them so I took it in.....motor was 60. and labor was 60.
Old Oct 23, 2008 | 04:34 PM
tndiesel's Avatar
tndiesel
I had my 5 yr. old hold the driver's control down and I lightly banged on the read passenger door and it went up. It ain't coming down anymore right now.
Old Oct 23, 2008 | 04:37 PM
Action4478's Avatar
Action4478
Read my sig .....
Old Oct 23, 2008 | 06:35 PM
scatgo's Avatar
scatgo
Mine wont go up. It thumps when I hit the button. I have to pull it up by hand while I hit the button.
Old Oct 23, 2008 | 08:31 PM
Hussler's Avatar
Hussler
Just FYI, all power on a CC goes through contacts on the drivers master switch first. If it fails then that window(s) will not work. Went through this earlier this year. I could roll down all three .. passenger front / rear and drivers rear but master would not roll then up. Had to use individual door switch to get them to go up. Did a lot of extensive VOM testing and finally pulled the master switch and opened it up. Inside the contacts were all green with water corrosion and those contacts (copper) were so tiny very hard to clean up. Bottom line I did not hurt anything but still same problem.
I probably searched the internet for a couple months and finally went to the dealership and got an entire master switch for $57. Ten minutes later it was installed and working great ever since. Not that it's your issue but though I would share.
Old Oct 24, 2008 | 06:26 AM
Cuda_jim's Avatar
Cuda_jim
The glass may be binding in the track. You might have some luck with spraying the tracks with silicone spray.
Any other oil will make a mess. Thumping at the bottom might be the bottom stop has loosened or needs adjustment.
If you keep using it like that the motor might burn out prematurely. Remove the door panel and lube up all the sliders.
Look for loose bolts and adjust the window if it cocking in it's tracks.
Old Oct 24, 2008 | 07:40 AM
93f1505.0L's Avatar
93f1505.0L
x2 on what Cuda said but IT really sounds like the problem I had with the gears. This is the kit Im talking about:
Google Image Result for http://thumbs300.1aauto.com/WRG/1AWRG00522.jpg
You can probly find it cheaper if you look around. This was the first one I saw with a pic. Anyhow the 3 rubber ***** (grey in this pic) ware out and the gear jumps around them. making the window jump when going up. Lube the runs and do everything Cuda said and it that doesnt help them I would say this is you problem. FYI if the motor has not been removed yet then you will have to drill the holes for them. There should be a spot already punched to drill. Not hard at all to do just drill them out big enough to fit a 10mm socket in there,
Old Oct 24, 2008 | 09:46 AM
Cuda_jim's Avatar
Cuda_jim
This the gear I ranted about in post #3 above:
Shop 1A Auto® for 1981-96 Ford F250 Pickup Truck Window Regulator Power Front Door Passenger Side for your F-Series Pickup
The circular gear in the picture above had 4-5 teeth ground off by the window motor gear.
The picture is for a front window but looks the same.
pdqtimetrialer
Jul 7, 2016 04:44 PM
rlay302
1983 - 2012 Ranger & B-Series
May 6, 2016 11:51 PM
F-150 MP
2004 - 2008 F150
Jul 30, 2015 08:38 PM
knabjordan
Aerostar
Mar 11, 2006 12:53 AM
hacksaw22
Nov 23, 2003 06:01 PM
