Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Stick, Mig, or
Old Nov 23, 2006 | 10:00 AM
daveengelson's Avatar
daveengelson
Stick, Mig, or
Back yard machanic with limited welding skills. Have an oxy/ace setup but have not seen much improvement in quality of the welds. Intend to use for sheet metal repair, floor pans, etc., nothing requiring major structural repair. Limited to 110/120v for now, hopefully no longer than 12 months, and looking for temporary fix. Not sure whether best to look for slightly used stick, or mig welder and wonder if any members have an opinion. Not that knowledgeable but usually can pick up skills with practice. Looking at Millor or Lincoln, have to do some research to determine which is best suited for the novice. Considering enrolling in classes but registration starts in couple of months, but involves consider commute, in meantime intend to check with local supplier find if anything local. Any suggestions, input appreciated.
dave
Old Nov 23, 2006 | 10:16 AM
Krochus's Avatar
Krochus
That pretty well rules out stick welding, it's pertty well impossible to use a stick for bodywork (oh it can be done but the guys who can make the mega $$$). SO I believe a good shielded gas MIG setup would best fit your needs.
Old Nov 23, 2006 | 11:31 AM
Greg 79 f150's Avatar
Greg 79 f150
Miller 135 mig
Old Nov 23, 2006 | 11:43 AM
khadma's Avatar
khadma
Carpenter Local 745
I sleep with my Millermatic 135, Home Depot sells Lincoln 135 ranger welders too for a lower price, some have gas option, Gas will produce cleaner welds, but gas is pricey for the hobbyist. I would practice on similar scrap metal to your finish project to get used to the temp/feed settings. A small 135 range welder will work fine on sheet metal. Miller recommends MIG welders for novices, most welding stores have demo machines for you to try. Look for one near you and burn some steel.
Aloha d.
Old Nov 23, 2006 | 12:07 PM
daveengelson
Appreciate the info. Came across couple Miller 135 'like new' units for around $350 one of which includes helmet, regular, and bottle. Any reservations about purchasing used. Tend to prefer purchasing local in event have any problems.
dave
Old Nov 23, 2006 | 12:19 PM
khadma's Avatar
khadma
Carpenter Local 745
Have the used unit looked over by a dealer, if that is possible, Millers are well made and very reliable. The are designed for the professional and durability is key. 350.00 is a good deal. Make sure the gun and ground is with the unit too.
Also make sure the instructions are there and you should be good to go.
Have fun
Aloha d.
Old Nov 23, 2006 | 01:43 PM
daveengelson
Whet to Miller web site and downloaded instructions and manual. Appears website also offer online training, will check it out when time permits. Intend to call local dealership see if any reconditioned. The unit referred to in prior thread was on ebay and seller's feedback rating not that good, not worth the risk. Probably try and locate locally even at additional cost.
Also, saw a 110/120v spot welder, any members have any experence with them. Probably would not have any reservations if able to use the 220v. Again, appreciate the input.
dave
Old Nov 23, 2006 | 02:05 PM
Ford_Six's Avatar
Ford_Six
Get a Millermatic 210, it's a 220 machine, but you won't need to upgrade later when you do any structural work. You can run any wire through it from .020 for thin sheetmetal to .045 for heavy structural work. You can even run 71-T1 steel and 309-LT1 stainless dual-sheild wire for better welds outdoors.
I would stay away from the smaller machines, since they are generally maxed out doing sheetmetal work. It's better to spend a little more now than to spend that much all over again to upgrade.
Old Nov 23, 2006 | 03:02 PM
daveengelson
As noted, limited to 110/120v for awhile and looking for a fix for year or so. Would like to go with the 220v unit; unfortunately, faced with delimma whether to get the 220v unit and see if my generator can keep up, or go with the 110/120v Millermatic 135. Food for thought, think I will check with local dealership see if willing to loan 220 setup and if it works apply to cost of unit. Although would be committed to purchase either way dealer would be making a sale.
dave
Old Nov 23, 2006 | 03:11 PM
Ford_Six's Avatar
Ford_Six
A friend of mine in an apartment complex runs a 125' extension cord from his dryer receptical in the apartment to his garage to run the welder.
Well, actually, I am borrowing the extension cord now so I can run my Dynasty out in the yard and throw my 72 back together.
jimbo1969
Jul 26, 2016 10:03 AM
Kierobi
16
Oct 31, 2015 09:26 AM
53OlderThanMe
90
Dec 2, 2007 09:53 PM
WillyB
N. California Chapter
Mar 10, 2006 10:31 AM
sigtauenus
Paint & Bodywork
Oct 25, 2003 07:46 AM
