Sponsored by: Real Truck
airbag key replacement cost?
Old Nov 22, 2006 | 05:56 PM
jgeis's Avatar
jgeis
Question airbag key replacement cost?
I'm looking at buying a Ford F250 from an individual, but the airbag light is on. He says it only needs a new key that would only cost around $60-$70. Does anyone know if this information is correct?
Old Nov 22, 2006 | 08:37 PM
johnsps250's Avatar
johnsps250
I don't have any idea of the cost of a replacement key. But, I am assuming talking about a key for the disable key switch on the dash for the passenger side air bag? If so, on my 2001 it is the same key the as the ignition.
Hope this helps.
John
Old Nov 22, 2006 | 09:45 PM
Musicman250's Avatar
Musicman250
I have a 2000 and its the same. Ignition key for the airbag
Old Nov 22, 2006 | 11:56 PM
blackhat620's Avatar
blackhat620
jgeis,
Welcome to FTE lots of good people and info aroung here
You may want to look at this truck a little more closely. Either the seller doesn't know what he is talking about, or he knows there is a problem with the Air Bag system in the truck. If the ignition key doesn't fit the lock there is a problem. Also the truck may have been wrecked and the air bags not replaced or not replaced correctly.
You may want to have this truck checked out more thoroughly by your mechanic before you decide to buy it. Something doesn't sound right about this sellers story.
Hope this helps
Old Dec 1, 2006 | 07:39 PM
jgeis's Avatar
jgeis
airbag SWITCH replacement cost?
thanks to those of you who posted. i didn't use the right wording. the truck has been wrecked and airbags replaced. the ignition key does work for the airbag, but the airbag light comes on when truck is started. the airbag light blinks twice, then seven times, then stays on (if this helps). i was told the airbag switch needed to be replaced costing about $70. does this sound ligit.? thanks.
Old Dec 1, 2006 | 07:52 PM
blackhat620
jgeis,
I am not an expert on Air Bag light flashing sequence, but if it was wrecked , i am guessing there was something done incorrectly when they replaced the air bags. Or they didn't replace the airbags and just said they did. If the truck was repaired by a reputable and qualified shop then there should be no air bag light. Something is definitely wrong in the system, i personally would not buy the truck until you take it to an ASE Certified Ford mechanic and have them diagnose and fix the air bag problem. Just seems odd that the person who is selling the truck had it repaired after it was wrecked, but accepted it from the repair shop with the air bag light illuminated. The insurance company paid to have this truck fixed properly, something seems fishy.
Hope this helps
Old Dec 1, 2006 | 07:57 PM
Bob Ayers's Avatar
Bob Ayers
You may want to run a CARFAX report on it to see what shows up in history...
Old Dec 2, 2006 | 07:14 AM
RAMBOv10's Avatar
RAMBOv10
I did a search and found this:
https://www.ford-trucks.com/forums/2...code-37-a.html
Of course it is for a F-150 but it may be what is wrong with yours. Does your light light up at the key disable switch?
CCBennett_1
2004 - 2008 F150
Mar 23, 2010 07:29 AM
CanadianRanger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 12, 2006 09:37 AM
Stube311
Mar 1, 2006 01:16 PM
loriruthj
May 22, 2004 10:00 PM
RCOAPSTICK
1997 - 2003 F150
Apr 2, 2004 09:45 PM
