Memory Code 212
Old Nov 20, 2006 | 04:41 PM
Monty06's Avatar
Monty06
Exclamation Memory Code 212
hey guys i just bought a 92 ford explorer 4.0 4x2 a4ld everything was going fine until just two days ago
when i got two codes 172 hos2 sensor system bank 1 lean
and 212 loss of idm input to pcm or spout circuit grounded.
i'm at a loss here please help thanks MONTY
Old Nov 20, 2006 | 05:21 PM
Coastiejoe's Avatar
Coastiejoe
Lean bank codes normally point o a vacuum leak. Use a spray can of WD 40 and spray all around your vacuum hoses as well as you intake gasket. If it revs up or stalls out, you found your issue...
Old Nov 21, 2006 | 01:32 PM
Monty06's Avatar
Monty06
thanks for that info does anyone know how i can fix that code 212
Old Nov 21, 2006 | 03:36 PM
Coastiejoe's Avatar
Coastiejoe
Your idle will seriously be affected by a vacuum leak. So, service, (test for) the vacuum leak first, the code may fix itself. Once you find the leak and service it, you will need to clear or reset the code.
finallyo3gt
May 1, 2016 12:49 PM
GreaseGun Joe
Aug 16, 2015 02:03 PM
Monty06
Jan 20, 2006 11:18 PM
Monty06
Bronco II
Jul 26, 2005 11:36 PM
Monty06
Nov 10, 2004 12:44 AM
