Long weekend
Old Nov 20, 2006 | 02:49 PM
John311t's Avatar
John311t
Long weekend
So i get home from work on friday to see that my new filter the 6637 had come. So i go to put it on and i found out i needed a 10 inch piece of 4" pipe. When i originally looked, i did not think i would need one but i guess i was wrong. Wow, what a diffrence no air box makes.
Sunday i decided to tackle the glow plugs since the truck would not start for like 15 minutes if i did not have it plugged in. So i get the left side done without any problems. I thought i got the right side done but when i went to start it I pulled a 1316 code for an IDM code. So i start getting scared that i somehow fried the IDM. So then i look in my trusty service dvd and it gave me a hint to unplug the VC harness. I did and nothing changed so i had to take the VC back off to find out that the connector on the opposite side was a 1/4" out of the female end. So i push it back in and i was good to go. It was a kinda cold mourning and it started like it was nothing.
Old Nov 20, 2006 | 03:19 PM
pullinair's Avatar
pullinair
Ive been lucky with 160,000 miles and no glow plug issues yet. You make it sound farelly easy. I havent been under my valve covers yet and i hope i get one last winter out of my plugs. 6637 is sweet isnt it!
Old Nov 20, 2006 | 03:42 PM
ponch37300's Avatar
ponch37300
I just did the drivers side gps the other night, got to late to do the passenger side. I've read about the uvc clips comming undone being a common problem. When i took my cover off the two peices of plastic that lock the clips together, one on inside and one on outside, were missing. Wonder where the one on the inside ended up and if it did any damage to anything. I was told the 03, my year, had the new clips that didn't pop off. Guess mine didn't.
Old Nov 20, 2006 | 04:18 PM
rad1026's Avatar
rad1026
10" piece of pipe? How did that work? I used a 3-1/2" piece between the filter and the intake tube. That's all I could fit in there.
Old Nov 20, 2006 | 05:14 PM
powrstrkn''s Avatar
powrstrkn'
rad,
If I were to guess he eliminated the first rubber tube and plastic ccv pipe all in one shot. Its about 10" long or so
Old Nov 20, 2006 | 09:49 PM
John311t's Avatar
John311t
I got rid of the plastic ccv piece, I still got all the rubber tubes in place. Getting the glow plugs out is not hard, but it was very time consuming for me. This is the first time i actually "worked" on a diesel engine so i took my time and printed out directions on how to take off the valve covers. I did not want to screw anything up. I went ahead and threw my valve covers and IC pipes in a part washer and washed them because they were dirty. I worked very slow and it took me 6 hours from start to finish. I would have been done in like 4 hour but i sat there for an hour throwing tools and causing a ruckus because i thought a somehow blew up the IDM until i pulled the service DVD out. I love the 6637! I will take pics tommorrow to show the 10" piece of pipe.
Old Nov 21, 2006 | 06:39 AM
Kwikkordead's Avatar
Kwikkordead
Congrats on the completed job.
I like working on diesels a lot more than gassers, there's less to them and once you understand them, they are easier to work on.
Old Nov 21, 2006 | 07:29 AM
John311t's Avatar
John311t
It seems easier to me! I think changing these GP is easier than changing the spark plugs on a 5.4.
Old Nov 21, 2006 | 07:36 AM
mueckster's Avatar
mueckster
Amen to that brother!
truckeemtnfords
19
Jun 18, 2014 02:21 AM
farmert
Nov 25, 2012 11:15 AM
commandersander
Sep 18, 2012 07:05 AM
consol
Apr 4, 2012 09:26 AM
coreylasalle
63
Dec 13, 2011 06:15 AM
