cold temp wastegate noise?
Old Nov 19, 2006 | 08:55 PM
crew01's Avatar
crew01
i have a 2001 f350 7.3, when the outside temp starts to cool down my truck start making a noise at certain rpm's. It sounds to me like a waste gate valve dumping pressure but i am not sure. it will quit if you apply more gas or let out completly. Can anyone help me with this issue? the truck also idles hi in cold temps but comes back down when you tap the brake. is this normal? thank you all for any help you can give.
Old Nov 19, 2006 | 09:06 PM
Uzumati's Avatar
Uzumati
That is the cold weather warm up mode. Tapping the brake exits it. What you are hearing is the Exhaust backpressure valve closing to speed warmup.
Old Nov 20, 2006 | 06:59 AM
ponch37300's Avatar
ponch37300
So while I'm driving at certian rpms it makes the noise and seems to have less power until you hit the go pedal a little. Is this what your talking about? It's normal while i'm driving? It only happens when it's cold out. Thanks
Old Nov 20, 2006 | 07:19 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
100% normal, sounds like all is working just as it should...
Old Nov 20, 2006 | 09:51 AM
John311t's Avatar
John311t
You can disconnect it so that it does not close anymore, although is will take longer to warm up.
fordman19762003
Dec 14, 2013 11:04 PM
jeffhead
2004 - 2008 F150
Feb 17, 2007 06:53 PM
01' Super Crew
1997 - 2003 F150
Feb 20, 2006 11:33 PM
billydsr1
Jul 25, 2005 02:57 PM
mike
Jan 18, 2001 08:15 PM
