temp sending unit
Old Nov 8, 1999 | 04:22 AM
mike
Guest
Posts: n/a
temp sending unit
can anyone tell me where the temp sending unit is on my truck. i have a 65 swb,240 3sp it has a temp guage but when i turn the ignition on it goes to full hot then slowly falls back down to cold and never moves again. i was going to start with sending unit and go from there. if anyone has a suggestion fell free.
Old Nov 8, 1999 | 08:18 AM
StockMan's Avatar
StockMan
temp sending unit
The sending unit is located toward the rear of the block on the passenger side above the starter. Sounds like your gauge is working correctly and the sending unit is probably bad. However, is your engine actually heating up to temperature (ie, does heat blow in the cab)? The reason I ask is that the thermostat might be stuck open or missing as another possibility. I hope this helps.
Stock Man
1967 Galaxie 500 Convertible (HELP!---I need 15 x5 factory rims)
1967 F-250 FE 390 4wd
1966 F-250 I6 240 2wd LWB Flare Side
<a href="http://www.hometown.aol.com/tbeeee">http://www.hometown.aol.com/tbeeee</a>
Old Jan 18, 2001 | 12:24 PM
66worktruck's Avatar
66worktruck
temp sending unit
Old Jan 18, 2001 | 08:15 PM
66ranger's Avatar
66ranger
temp sending unit
Just a thought: Do the other gauges work properly?? The temp and fuel run thru the constant voltage regulator on the reverse side of the instrument cluster. The optional oil gauge runs thru it, but the optional amp gauge does not. It runs thru a 70 amp circuit breaker instead. If other gauge problems exist, I would check into this little part. Temp senders are cheap & common to replace however...
comet
Oct 13, 2008 10:29 AM
Gage2502
Modular V8 (4.6L, 5.4L)
Feb 25, 2008 07:34 PM
tawd77
Feb 5, 2007 08:17 PM
agreder
Apr 27, 2005 05:43 AM
shami02
Sep 16, 2000 07:58 AM
