Sponsored by: Kumho
Loose Steering
Old Nov 19, 2006 | 12:11 PM
FordF350Baby's Avatar
FordF350Baby
Loose Steering
Hey guys, I have a 1995 Ford F350. Big Block 460. I have some play in my steering wheel. I was told to replace steering box, and alignment. That didnt help. I had retightened, didnt help. Replace universal joint, didnt help. $700 later, still loose. Any idea what it is. When i drive i have to correct in constantly. I doesnt retract after turns, theres no firm grib, its very wooshy, and its very annoying. My truck is awesome, but driving it can be a headache . Heres some pics. http://www.picturetrail.com/f350baby
Old Nov 19, 2006 | 12:55 PM
stuart1's Avatar
stuart1
Check the track bar.
Start the engine.
Sitting in the drivers seat turn the wheel 1/4 turn either both ways.
Watch the front of the hood.
If it moves back and forth the track bar is toast.
Old Nov 19, 2006 | 01:45 PM
FordF350Baby
Thanks Man, I will go try it out. What does a track bar do by the way, whats it for?
Old Nov 19, 2006 | 04:37 PM
stuart1's Avatar
stuart1
It's like the good book.
Keeps you on the straight and narrow.
Old Nov 19, 2006 | 04:53 PM
buffalobob's Avatar
buffalobob
check the steering column shaft...under the hood there is a portion of it that has provision for sliding in-out....that wears and you get the drunkin sailor steering response...cant be repaired..if thats it...replace that section..or go to a junkyard and get whole steering column
Old Nov 19, 2006 | 05:57 PM
FordF350Baby
alrightyyy
Old Nov 20, 2006 | 05:59 AM
SRD4X4's Avatar
SRD4X4
If it does'nt come out of a turn,then something is too tight.Normally it's box adjustment.But since replacing it and adjusting it didn't help.Jack it up,knock the tie-rods loose,and the wheel should "flop" back/forth,if it does'nt you've got a balljoint thats "dry" or a bad axle u-joint.
Old Nov 20, 2006 | 02:42 PM
FordF350Baby
The universal joint was just replaced too. So my guess is just look you said is a ball joint. Its the only thing that hasnt been replaced. Also i think its that too because what i take a turn in a parking lot when you have to have the wheel completely turned to make a big cirlce, theres a weird vibration/shaking coming from the wheel, so I think its that to.
trinibob
Modular V10 (6.8l)
24
Sep 6, 2010 12:57 PM
FordF350Baby
Paint & Bodywork
Jul 15, 2008 12:34 PM
FordF350Baby
Exhaust Systems
16
Jan 21, 2008 09:24 PM
FordF350Baby
Appearance & Dress-Up
22
Aug 29, 2007 02:14 PM
FordF350Baby
Aug 18, 2007 02:42 PM
