Priming the fuel system
Old Nov 16, 2006 | 11:45 AM
Freakazoid!'s Avatar
Freakazoid!
How to do it? I read a couple of old posts (welcome back search function!) that talked about removing fuse #9 and crank the engine a few times, wait 3 minutes, repeat...a lot. Is this how the factory would do it? I have replaced the fuel pump and had pulled out the fuel bowl for cleaning, so my system is pretty much empty. I was thinking along the lines of this:
Refill fuel bowl
Crank engine a few turns
Vent the system through the schrader valve - which will be moved to a higher point since I am installing a fuel pressure gauge.
Repeat as necessary
Would this work or are there better ways to do this?
Old Nov 16, 2006 | 02:23 PM
tjbeggs's Avatar
tjbeggs
you should be good just to fill the bowl and crank and rest just a few times. it may even fire the first crank time with the bowl filled. shouldn't have to crank for a terrible long time. it may run bad for a minute but not too bad.
1950F47
13
Apr 14, 2014 05:15 AM
wezol5484
15
Feb 19, 2014 03:03 PM
baconmobile
17
Jan 23, 2011 07:50 AM
C350CREW
Nov 15, 2010 12:15 AM
rigoberto
Apr 10, 2009 09:51 AM
