Diff
Old Nov 16, 2006 | 11:33 AM
metal_mullisha's Avatar
metal_mullisha
Diff
How can I tell what kinda diff I have in my 02 ford explorer limited? I think it is failing, and need to know how to figure out what kind to order. Also how do I tell if I have limited slip? I changed the oil about a month ago and didn't put any additive in the diff. I also had a flat tire on the hiway and my spare was a different size(bigger) and when I drove my truck would jerk, would this have caused a failure in the diff?
Old Nov 16, 2006 | 12:09 PM
aquanaut20's Avatar
aquanaut20
Check the tag on the diff,
call the stealer with your VIN, they can tell you
Old Nov 16, 2006 | 12:42 PM
Steina's Avatar
Steina
CO River Rat
Look at your receiver hitch. If it's 1-1/4" with a 4-pin electrical connector, you've got 3.55 rear gears; if it's 2" with a 7-pin connector you've got the 3.73 LS.
How far did you drive with the larger tire?
Steve
Old Nov 16, 2006 | 03:01 PM
metal_mullisha
I drove about 60km to the next town with the larger tire.
Old Nov 16, 2006 | 03:34 PM
Steina's Avatar
Steina
CO River Rat
That might've done it, especially if it was sick to begin with - the diff thought you were constantly going around a curve.
What do you have - the 3.55 or 3.73 LS?
Steve
Old Nov 16, 2006 | 04:55 PM
steve(ill)'s Avatar
steve(ill)
driving with two different size tires is not a real big thing. driving a limit slip differential with out the friction modifier is not a good idea. if you had two different size tires, and the differential is constantly rotating due to the different sizes, AND you have a LS rear end witihout the addative, then you have a problem. The clutches surely took a beating. if it is salvagable by adding the oil now, or needs rebuilt, is hard to say. How does it act now???
Old Nov 16, 2006 | 09:21 PM
metal_mullisha
I have the 3.73ls rear end, it just make a noise at a consistant turn/curve. Can I add the additive now, or should I change the fluild again and add it to the oil? How hard is it to change the Diff? does it take along time?
Old Nov 17, 2006 | 11:09 PM
steve(ill)'s Avatar
steve(ill)
there is a big drain plug like 1 inch and a small fill plug about 1/2 inch pipe above and front side of the differential. i would go to Auto Zone and get a tube of the friction modifier and just add to the present oil and see what happens.
Old Nov 19, 2006 | 09:47 AM
AxleEngineer's Avatar
AxleEngineer
Add 5 oz of friction modifier from your Ford Dealer, not Autozone, and it may be fine.
Old Nov 19, 2006 | 10:51 PM
metal_mullisha
is the rear end in my explorer a 7.5?
