Front end alignment question
Old Nov 15, 2006 | 10:38 AM
OzarksFord's Avatar
OzarksFord
I called the local service station about an alignment on my 1983 Ford F-150 (2wd). The quoted a price plus parts if needed (alignment bushings). Does my F-150 use alignment bushings? I would like to know what my possible costs will be before I take it in.
Thanks!
Old Nov 15, 2006 | 10:49 AM
Sport45's Avatar
Sport45
Most likely all you will need is toe-in adjustment. Should cost less than $50. Caster is not really adjustable and camber is done with eccentric bushings. Camber bushings cost about $12 each if you buy them or $50 each if the alignment shop installs them. But like I said, you probably won't need them unless you've changed springs or bent an axle.
gopher2
13
Oct 14, 2012 04:47 PM
Thumper19
Oct 12, 2011 06:33 AM
keisha9
2004 - 2008 F150
Mar 5, 2011 10:06 PM
sandman3510
Jul 20, 2004 12:30 PM
gingerbreadmaniac
16
Aug 14, 2003 08:29 AM
