Rust Encapsulator
Old Dec 5, 2006 | 04:34 PM
fordpick-up's Avatar
fordpick-up
Just looked at your pics carras and that is one fine looking truck. Looks like you don't even have any rust left on that frame just nice shiney metal.
Old Dec 5, 2006 | 04:37 PM
fordpick-up
I forgot to mention if it's too slick (the prep work) you may have trouble with the rust encapsulator bonding to the metal.
Old Dec 6, 2006 | 08:23 AM
bob1987f's Avatar
bob1987f
I brushed it on so It would go on thicker. I got a pack of those cheap foam brushes from Northern Tool and Supply for like 5 bucks. I only applied one coat as well, and a year later it still looks great
Old Dec 8, 2006 | 09:26 PM
carras's Avatar
carras
guys, thanks for the tips. looks like i'll need to hit it with 8o grit before painting.
Old Dec 10, 2006 | 10:07 AM
Greg 79 f150's Avatar
Greg 79 f150
Also the encapsulator should be scuffed with a red scotch bright pad (or 400 dry sand paper) and then cleaned, to promote adhesion of the chassis black finish coat. I have had to re-do some of my chassis parts where the chassis black flaked off , wherever I did not scuff the primer first. ...
I do not know if the new encapsulator ( it was called Corroless back when I put it on mine 5 years ago) can be top coated wet on wet or not. If so, that technique would be the way to go, and a heck of a lot easier than scuffing all of the chassis suspension parts with pad or paper. good luck. jmo
Old Apr 22, 2009 | 01:09 AM
fordpick-up
Two years and working on almost three and still no rust. The rust encapsulator works great.
mustang_309
Nov 14, 2014 10:43 AM
troy676
Jul 5, 2014 11:28 PM
bookum1
Modular V10 (6.8l)
Nov 13, 2007 09:37 PM
XxfirmanxX
Feb 28, 2006 02:37 PM
fordeverpower
Jul 14, 2004 11:15 PM
