Sponsored by: Auxito
Engine Knocking
Old Nov 14, 2006 | 07:35 AM
chopperpilot's Avatar
chopperpilot
Engine Knocking
My 1998, V6, makes a noise such as the lifters loose. Someone said that it was the rod bearings, I had them replaced, the noise never went away. Someone else said the oil is not flowing all over the engine.
What viscosity would be better to muffle the noise a lighter or heavier oil (10 vs 50) and what do I need to do to fix it up once for all.
Old Nov 14, 2006 | 07:54 AM
scottie2hottie's Avatar
scottie2hottie
I recomend a heavier oil in a higher mileage engine, but in my experience the opposite reduces lifter noise. I'm not 100% about the modular engines(including your V6) but in older engines lifters are not difficult to change. I would recommend that, it's as easy as a few simple tools and a gasket set usually. You will probably need a torque wrench for the rockers, however.
Old Nov 14, 2006 | 08:25 AM
chopperpilot
Scottie, thanks for the quick reply, I'll try a lighter oil, first. On the weekend I'll take a look at the lifters...Aren't this lifters hydraulics and they are supposed to be self adjusting or so I thought, tha's why I didn't try that first.?
Old Nov 14, 2006 | 10:17 AM
scottie2hottie
To be honest I really have no idea- mine doesn't/hasn't made any engine noises YET so i haven't tore into it
Old Nov 14, 2006 | 10:58 AM
Joe Finn's Avatar
Joe Finn
I'd make sure it's not an injector ticking before you tear the engine open. Injectors can sometimes sound just like a lifter.
UNTAMND
Modular V10 (6.8l)
Jun 20, 2014 07:48 PM
srauner
Jan 27, 2014 02:29 PM
jlr1073
Feb 22, 2010 10:04 AM
hatz
May 11, 2009 11:30 PM
LiveFast
1983 - 2012 Ranger & B-Series
15
Jun 7, 2004 07:14 PM
