X Engine Noise
Old Jan 20, 2014 | 05:43 PM
srauner's Avatar
srauner
X Engine Noise
I had my truck (2003 X 7.3, 248,000 miles) in for some service last week. Among others, I had the transmission flushed. After the requested service items were completed, the service manager called and said the transmission is making a strange, intermittent noise. He said they checked torque on torque converter bolts but the noise persisted. They wanted to pull the transmission and look further. I declined this offer, because with 248,000 miles I intend to drive it 'til it dies and then worry about what to do with it.
Anyway, I drove it home and the noise was significant, but more importantly, it was a noise I had never heard up to this point. I took the attached video this afternoon:
https://www.youtube.com/watch?v=BuVO...ature=youtu.be
I'm no transmission expert, but this does not sound like a transmission noise to me at all.
It sounds awful sharp and metallic, but could this be an exhaust leak?
Old Jan 20, 2014 | 06:23 PM
EXv10's Avatar
EXv10
It sounds like either loose converter to flywheel/flexplate bolts or a cracked/broken flexplate. Take the cover off in front of the converter and take a look.
Old Jan 21, 2014 | 08:53 AM
srauner's Avatar
srauner
They said they checked the converter bolts. I would think if they did that any obvious issues would have been identified.
Old Jan 21, 2014 | 11:30 AM
EXv10's Avatar
EXv10
Maybe. It sounds like something in the converter area. That much noise can't come out of the trans inside and still be working right. It's hard to see a crack in the flex plate.
Old Jan 21, 2014 | 11:35 AM
wrxin's Avatar
wrxin
I've been doing all kinds of research about flushing and whether its good or not. Do you know if they used a cleaner or some type of cleaning additive?
Do you know how the fluid was forced through? (was the truck running and the trans pump was flushing the fluid or was the car off and they forced the fluid through?)
I have spoken with a number of diesel/trans experts in my area and one of them warned against a flush could send the fluid backward through the trans, basically flushing all the bad sediment back onto the clutch plates). I don't know if that's possible but it makes sense that it would be bad.
From what I've read, if your trans is getting near the point of needing a major overhaul, a bad flush can just accelerate the problem.
Old Jan 21, 2014 | 11:38 AM
wrxin's Avatar
wrxin
I just listened to your video, sounds terrible. Whatever you do, I wouldn't drive it very far.
Hopefully our resident, super helpful, transmission expert Mark Kovalsky will chime in.
Old Jan 21, 2014 | 12:06 PM
EXv10's Avatar
EXv10
Too bad they quit putting drain plugs in the converters. I guess they want you to take it to the dealer for a flush.
Old Jan 21, 2014 | 02:02 PM
wrxin's Avatar
wrxin
No kidding. I called 3 dealers within an hour of my house and none of the service managers really knew what they did for a flush. They knew very little about their equipment or (in my case) the requirements for a 5R110 flush. I know the trans in this thread is easier to flush because it doesn't have to be heated but none of the dealers really seem to know what they are doing.
I am going to stick to draining what I can out of the pan and doing that regularly and skip all this flushing nonsense. That's what the original service schedule called for anyway. I am glad they put a drain plug in the pan of the 5R110. I just finished replacing the trans fluid on our 96 Blazer and after being sick of the huge mess it makes, I installed a drain plug. It'll be much better next time.
Old Jan 21, 2014 | 02:20 PM
EXv10's Avatar
EXv10
I guess you saw my write-up on draining the trans. It's pretty straight forward.
Old Jan 21, 2014 | 02:25 PM
wrxin's Avatar
wrxin
Oh its as easy as pie on the 5R110. Just pull the drain plug and replace what comes out. I'm also changing the toilet paper while I'm under it.
Old Jan 21, 2014 | 04:12 PM
srauner's Avatar
srauner
I took it in to the dealer today. They said the flex plate is definitely broken, and it may have something to do with at least 2 transmission mounting bolts missing - said the transmission is 'very loose.'
Old Jan 21, 2014 | 04:15 PM
EXv10's Avatar
EXv10
I thought they checked all that?
Old Jan 21, 2014 | 05:06 PM
srauner's Avatar
srauner
The previous work was not performed by the dealer. The dealer is normally booked full up, so I had taken it to a diesel repair shop in my little town. Has a good rep, but if they checked converter bolts and did not see 1) a broken flex plate and 2) missing transmission mounting bolts then I am somewhat disinclined to share in the positive vibes.
Old Jan 23, 2014 | 11:39 PM
crazytwo's Avatar
crazytwo
OMG! That noise sounds horrible. Hopefully it won't cost too much to fix. I will never do a transmission flush. My Ex has a transmission drain plug. I just drain and fill until I do a full service.
On vehicles that don't have a drain plug, O’Reilly's has a drain plug kit for about 5 bucks.
Old Jan 24, 2014 | 12:27 AM
EXv10's Avatar
EXv10
That sounds good. How does that kit work? I will never flush mine either.
