wierd noise please help me
Old Jun 5, 2004 | 08:19 PM
LiveFast's Avatar
LiveFast
Angry wierd noise please help me
Hey guys I have a 98 ranger 4.0L , I have only had it about 4 months and there is a wierd noise that sounds like a ball bearing rolling around in side the transmission i have already checked the pulleys and they are all fine i also had a new slavecylinder and throwout bearing. The guy at the transmissionshop said that the springs on my pressure plate were loose do u think that could be making the noise or does anyone have any idea what it could be? Please help me its bugging the crap out me......
Thanks,
Livefast
Old Jun 5, 2004 | 09:49 PM
xlt4me's Avatar
xlt4me
Thanks,
Livefast
Did you try turning the radio up? At least you don't have to worry about being constipated (sp?)
If it is the sound I am thinking of it is not uncommon for all manual trans. It is more noticable in warm weather when you first start it up or when your sitting at a light in neutral. The fluid drains off the parts in the trans and there is more free play so the gears rattle on the shafts.
Don't most Ford manual trans spec ATF for their fluid? You could try somthing thicker like Redline MT90. The trade off is second gear may be a little notchy until the gear oil warms up.
Old Jun 5, 2004 | 10:34 PM
el conquistador's Avatar
el conquistador
are you sure it is coming from the tranny? could be a vibration on the exhaust pipe. the exhaust system can make weird noises. make sure everything is tight.
Old Jun 6, 2004 | 07:03 AM
LiveFast's Avatar
LiveFast
I tried putting in some of that lucas transmission fluid thats suppose to help with worn parts and it didnt help do u think that redline mt90 would be better????
Old Jun 6, 2004 | 03:17 PM
bassaway's Avatar
bassaway
I have a manual and it makes the same noise as well. Its made the same noise since i bought the truck and I beleive that it is normal.
Old Jun 6, 2004 | 07:10 PM
xlt4me's Avatar
xlt4me
If that is the problem I think it would. Changing the fluid can't hurt. I tried many different brands of gear oil in my Stealth in order to improve shifting and still be quiet. I ended up blending my own concocktion of Mobil 1 ATF and straight 140 weight G4 gear oil. It's a long story of how I ended up with that but it works best for that car -- for me.
Old Jun 6, 2004 | 07:13 PM
xlt4me's Avatar
xlt4me
I've spent a lot of time lurking on the Miata and Corvette boards and I know it is common there. I've also had it on my Stealth.
Old Jun 6, 2004 | 11:13 PM
el conquistador
these manual trannies call for ATF not gear oil. if you use gear oil, the oil can't get to all the places in the tranny, b/c of its thickness, that the ATF can, thus causing problems, most notably harder shifting. there was a big arguemnt about whether to use ATF or Gear oil, so im not telling you to use ATF, but it is recommended by Ford.
Old Jun 7, 2004 | 12:48 AM
Distilld's Avatar
Distilld
The tranny on my '03 4.0 FX4 is a bit on the noisy side going down the road at speed even. I swapped out the fluid with B&M Trick Shift Synthetic ATF and it helped both the noise and the shifting smoothness considerably. It didn't eliminate it but it sure helped. Just my 2 cents.
Old Jun 7, 2004 | 09:22 AM
xlt4me's Avatar
xlt4me
You may want to check out bobistheoilguy.com for more advice. They have a transmission fluid section. There is a lot of good info on that board.
Old Jun 7, 2004 | 09:56 AM
bassaway's Avatar
bassaway
My truck makes the noise only when the clutch is engaged. When I press down on the clutch the noise stops. Like i said, it has always done this.
Old Jun 7, 2004 | 10:08 AM
LiveFast's Avatar
LiveFast
Bassaway I think it sounds like u need a throwout bearing mine did the same thing until I put a throwout bearing you might just want to have it checked out just my opinion....
Old Jun 7, 2004 | 10:42 AM
bassaway's Avatar
bassaway
Livefast,
Did you replace the throwout bearing yourself or did you hand it over to a mechanic? if so, how much damage did it do to your wallet?
Old Jun 7, 2004 | 12:37 PM
smithc185's Avatar
smithc185
Alright i have run into this problem with my 02 B3000 5 speeed. There was always a noise like something was knocking around inside of my transmission. I took it to the dealership since it was still under warrantee and they told me that my input shaft had to much play. They ended up rebuilding the whole tranny and putting a new input shaft in it. The thing about it is. Alot of these ranger pickups especially the 5 speeds have faulty throwout bearings and noises from tranny. I had just gotten my throwout bearing replaced and now its making noise again not even 500 miles after i got it done. So the noise is not hurting anything and if its outta warantee there is nothing much you can do about it unless you wanna pay to have your tranny rebuilt.
Old Jun 7, 2004 | 02:57 PM
LiveFast's Avatar
LiveFast
Bassaway,
It cost me 150.00 for labor and a throwout bearing and slave cylinder I thought it was pretty cheap of course the transmission shop is owned by my girlfriends uncle but he dont like me very much but that another story so I dont think that it made that much of a difference in the price.
Thanks,
Livefast
