Sponsored by: Auxito
Running rough 01
Old Nov 12, 2006 | 09:30 PM
01sport150's Avatar
01sport150
Running rough 01
I have a 2001 4.6. The truck seems to idle fine, but when driving down the road it will start to jerk when under a load. I just had the fuel injectors cleaned, new fuel filter, transmission input shaft replaced (weld broke). This jerk started before all the work, so I had brought it into the shop have them work on it, and the shop did the 60,000 mile service. A couple thousand miles the weld broke on the input shaft, transmission work was done at a ford garage. The problem is still jerking with no check engine light. I also notice that the fuel gauge would move up and down from ¾ to ½. On heavy accelerations the tack with go down and loose power, then pick up and go. Is this a fuel pump problem?
Old Nov 13, 2006 | 04:41 PM
BillyBob69's Avatar
BillyBob69
I know it may sound far fetched, but have your alternator and battery tested under load. If the alternator is not supplying the correct power output, then the computer will not operate correctly. A bad abttery could also cause a bad draw making the alternator change its output.
Old Nov 13, 2006 | 06:13 PM
01sport150's Avatar
01sport150
I have not checked the battery or the output of the alternator. Wouldn't I see the lights dim when driving at night?
Is a test with a voltmeter a correct way to check the output and battery? Or should I invest in another tool?
Old Nov 14, 2006 | 08:12 AM
BillyBob69's Avatar
BillyBob69
Take it to your local parts store. They can test it and usually for free. They have equipment that can add a load as it is running.
Old Nov 15, 2006 | 06:49 PM
01sport150's Avatar
01sport150
I have had the battery and alternator checked. They told me everything on that part looked good. It seems like it might be missing.
The dealership tells me to keep driving it (it will get worse and we will know whats wrong). I need to get this fixed.
What should I check next?
Old Nov 15, 2006 | 08:25 PM
steve(ill)'s Avatar
steve(ill)
the first think most shops do when you have a miss under load is put new spark plugs in the motor. normally this is more in the 80-100,000 mile catagory, but 60,000 could be a problem.
Old Nov 15, 2006 | 08:39 PM
01sport150's Avatar
01sport150
Should I replace the spark plugs? I've read that replacment of the plugs are not easy. If that is the place to start, what are the best plugs to put in?
Old Nov 15, 2006 | 08:47 PM
thehawk789's Avatar
thehawk789
well that would be the easiest and cheapest way and place to start. If you think its a miss.
just buy the $1.29 plugs.
but it could be a lot of things. bad wire? resistance on a wire should be 30-70K. But usually they will misfire at idle not high rpm. could be a bad plug though, it does happen and its random.
Old Nov 15, 2006 | 08:49 PM
thehawk789's Avatar
thehawk789
could be a bad pcm or bcm or a bad connection at either.... or bad connection between pcm and ignition control module.
Old Nov 15, 2006 | 08:56 PM
01sport150's Avatar
01sport150
Thanks, I'll start with the plugs.
Old Nov 15, 2006 | 11:46 PM
Racerguy's Avatar
Racerguy
Welcome to the forum 01sport150
For some tips on replacing the plugs take a look at https://www.ford-trucks.com/forums/1...=replace+spark
Old Feb 21, 2007 | 07:11 PM
01sport150's Avatar
01sport150
The check light never came on so i started with the #4 cop and plug.
Problem gone.
Thanks for all the help!!!!!!!!!!!!!!!!!!
06FUN
Oct 29, 2016 07:53 AM
ten.mile
Dec 11, 2012 05:56 PM
Morgan45
New Member Introductions
Feb 17, 2008 12:56 PM
Crazy-Man
Aug 24, 2007 07:35 PM
