guys with big trucks - spare tire???
Originally Posted by wera racer
what do you do for a spare? i have 37's and while i remember reading that a 37 might squeeze under where the spare goes, i dont think that will work with my 4" exhast. so do you just throw one in the bed, or is there a better idea to save space?
I have 33 inch BFG's mounted on Centerline Hellcats on my 99 and there's no way a spare would fit in the spare area. I ordered an extra rim and when I replaced my tires I kept one of them to use as a spare and have it in the back but am trying to figure out a way to mount it. In an accident that spare could fly right through the rear window and into the cab, which is something I wouldn't want.
I bought a 4x4 spare tire mount from Fabtech and am trying to figure out a way to possibly remove the factory tie down brackets and have a piece of metal fabricated that will mount in those holes and then mount the Fabtech spare tire mount to it.
I've tried to fit a 35"(35.3") Super Swamper SSR in the spare tire area with no luck. It pushed hard on the exhaust and the trailer hitch. I believe that without the trailer hitch it would've probably fit. Now I have my full-sized spare chained-up and locked to one of the factory tie-down rings in the bed, up toward the cab.
I've seen these, but I'm not sure I want one. --> http://www.tiregate.com/ <--
Hmm.. I wonder if there is a difference between models. I have the factory spare in mine and there is at most a 1/2 inch of clearance around it. The tires I am running are a lot taller and wider so I know it won't fit. I even remember getting the larger tires installed.. while it was on the stand I asked the guy if one of the larger tires/wheels would fit, he looked up and said "no way".
