MBRP 5"
Old Nov 16, 2006 | 01:01 AM
  #31
sweet03cobra's Avatar
sweet03cobra
Ford T-409 Stainless Steel 4 Inch Turbo Back Exhaust System #S6206409
Now would this be a good turbo back and would it give me the option to use my cat or not? Could I do this setup in my yard or would it have to be welded? I pulled this off MBRPs website.
Old Nov 16, 2006 | 05:41 AM
  #32
ford4lifer's Avatar
ford4lifer
I ordered that system yesterday, seem to me from what I've been told, you can do it yourself in your yard. Takes about 2 hours, most of that time getting the old system off, heard one guy say it only took him 15 min to put the new system on. And yes it uses your stock cat or you can purchase the cat delete for an extra $50. Also it doesn't have to be welded I guess you could if you wanted but once it welded it's there and if it cracks, the more you try to weld it the weeker stainless gets and those spots will start to rust out. I see this on polished marine stainless exhaust everyday.
Old Nov 16, 2006 | 05:45 AM
  #33
ford4lifer's Avatar
ford4lifer
Originally Posted by Mark at DPPI
ford4lifer,
Most likely the guy scaring peds has a 2003, the turbo whistle is much louder as the wheel is different on them, thrust me I know as I have one. I love it but for some a 2003 with no cat can be a bit much. Get the 4 inch unless you just want the look of a 5 inch and if you do you can always get our 4 -6 inch tip for the "look"! Call us we'll steer you the right way based on what you want.
Mark @ DPPI
Mark,
The build date on my truck is 09/03, does this mean I will have the louder turbo sound you are talking about? Also do you guys sell the muffler delete for the 409 stainless MBRP 4"? If so let me know, thanks.
Old Nov 16, 2006 | 11:39 AM
  #34
Mark at DPPI's Avatar
Mark at DPPI
sweet03cobra,
Cat back will get you approx 80% of the benefits of a turbo back system!
Mark @ DPPI
Old Nov 16, 2006 | 11:41 AM
  #35
Mark at DPPI
sweet03cobra,
Yes it will allow you to bolt your stock cat in place totally un modified. If you want to go catless you need the optional pipe that we also sell for those that want it. No welding required, a sawsall is nice to get the old system off thought not necessary! Call us if you have any questions we'll be glad to help you.
Mark @ DPPI
Old Nov 16, 2006 | 11:43 AM
  #36
Mark at DPPI
ford4lifer,
Maybe yes, that is the approx date when Ford started making some turbo changes so I can't tell you for sure. Yes we do sell the muffler deletes in 4 and 5 inches, aluminized, 409 and 304 stainelss.
Mark @ DPPI
Old Nov 17, 2006 | 02:04 AM
  #37
sweet03cobra
thanks for the info!
qwertmonkey
Nov 6, 2009 04:32 PM
only90s
15
Mar 30, 2009 07:29 AM
Madirishman
Feb 19, 2009 11:19 PM
powerstroke26
Jan 30, 2008 04:06 PM
03KingRanchF250
Nov 9, 2006 09:23 PM
