1978 - 1996 Big Bronco
Ponder this?
Old Nov 12, 2006 | 10:29 AM
Dude_Zilla's Avatar
Dude_Zilla
Ponder this?
I have been sitting on a fence post about this for quiet some time I have a 79 supercab and I am thinking of putting the cab on my 78 bronco frame I realize there will be some carnage. My question to all of you is have any of you pondered this or have any of you tried this or done it any comments or info will be greatly appreciated
Old Nov 12, 2006 | 10:57 AM
dwoodler's Avatar
dwoodler
Why even go to that extent? Is the frame on the Bronco toast? An engine and drive train swap has got to be easier than chopping a chunk out of your frame and then putting it back together again, not to mention aligning body mounts and eveything else.
I suppose you could do it but it would be alot of work. If you do do it, take lots of pictures and let us know how it went.
Old Nov 13, 2006 | 12:05 AM
Dude_Zilla's Avatar
Dude_Zilla
I was out under the super cab today and was doing some measuring the rear cab corners need to get cut out 14"in to accept the Rear wheel location's of the Bronco Frame also the Rear cab mounts look like they will just fit with little to none alterations The bronco is from quebec and the super cab is Alberta I keep hearing how impossible the out of provence inspections are theese days so IF anything I can build s one of a kind ford
Richard Collachi
May 4, 2014 08:45 PM
Kuskoal
21
Sep 29, 2010 01:34 AM
the_hetz
Feb 20, 2008 06:37 PM
nhill2090
36
Nov 16, 2007 12:14 AM
Dude_Zilla
Alberta Chapter
13
Feb 5, 2007 07:26 PM
