1978 - 1996 Big Bronco
Fuel injection
Old Nov 11, 2006 | 09:26 AM
garypettengill's Avatar
garypettengill
Fuel injection
Looking for help. What type of EFI system did Ford use in the '96 Bronco with the 5.8. Is it a mass flow system or a speed density system?
Old Nov 11, 2006 | 12:03 PM
lostin90s's Avatar
lostin90s
Both. If it dosent have the maf sensor on air box then (according to ones I've played ) its speed density . From 94 to 96 it was a mix of Maf trucks and non maf trucks. Unless you live in California and NY . I've installed few Maf 's on 93 up trucks . But I dont know everything. Good luck
__________________________________________
94 F150 XLT SC LB Maf 302 E4od
Old Nov 11, 2006 | 08:52 PM
408bronco's Avatar
408bronco
I am pretty sure all 96 Broncos had MAF 5.0 & 5.8. 95 had MAF in Calif and Speed density for other states. Not sure about the NY thing
Gary do you have a 96 or looking for one?
Old Nov 12, 2006 | 12:10 AM
garypettengill
Neither. Wondering about the possibilities of using a '96 5.8 EFI system to control an E4OD transmission and MAF EFI on a '77 6.6ltr. engine.
Old Nov 12, 2006 | 10:23 PM
alxsnmr's Avatar
alxsnmr
You may be able to obtain spacers to get the EFI to work on the 400. You can also purchase an aftermarket computer to control the E4OD for you. I have heard/read that the aftermarket computer was better than the Ford computer for controlling the E4OD.
Old Nov 13, 2006 | 09:09 AM
Kemicalburns's Avatar
Kemicalburns
96 is mass air OBD-II. meaning there is a sensor for everything possible. probably not the best choice due to complexity, any mass air setup with an a9l or a9p ecu would work. on pre 96 maf that was eec-IV so you could control the tranny still.
there is a guy on another bronco site that efi'ed his 400. screams from what i hear
HiTech
Modular V10 (6.8l)
Aug 11, 2002 01:28 PM
Lashlaroo
Aug 10, 2002 11:39 AM
gblakeney
Jul 22, 2002 06:30 AM
charlez
Dec 30, 2001 11:47 PM
Mulletwagon
Nov 10, 1999 11:08 AM
