312 rebuild questions
Old Aug 6, 2002 | 09:51 PM
tmn8tr's Avatar
tmn8tr
Should a person always have a block honed and decked prior to rebuilding?
Are there any other things I'm forgetting, besides porting the heads? .
I have found a machine shop here locally (CO. Springs) who have employees (older ones) who know Y-blocks, and I just don't want to sound like a total Idiot when I go in there.:-X11
Thanks in advance
Tim Goodwin
('58 F-100)
Old Aug 11, 2002 | 01:53 PM
54_5star's Avatar
54_5star
Proper finish in the cylinders is far more imoportant than porting the heads. Decking is nice as it give you a nice sealing surface for the head gaskets.
Old Aug 11, 2002 | 09:07 PM
tmn8tr's Avatar
tmn8tr
Thanks,
I took a look at the cylinder walls and they look pretty darn good, the crankshaft is another matter alltogether, the connecting rod bearings are showing copper on the high side. I'll take crank to the machine shop and have 'em mic it I guess.
T.
Old Aug 11, 2002 | 10:42 PM
darkhorse54's Avatar
darkhorse54
Take the block to the machine shop and have them mic the cylinders to see if you can hone them, if the cylinders are worn then have them bore the block no more than .030 if possible, also have them mic the crank and if it checks out ok then be sure to plastigage your rod and main bearings.
Old Aug 11, 2002 | 11:32 PM
bcguys's Avatar
bcguys
Erica V. Goodwin
Oct 23, 2014 05:32 PM
goodwin
Sep 3, 2014 09:07 PM
goodwin675
1997 - 2003 F150
Jan 4, 2014 09:36 AM
michaelgoodwin_47
Jul 17, 2006 11:35 AM
tmn8tr
Nov 10, 2002 08:02 PM
