What do I need to do to get more power out of my 351w?
Okay I'm 16, and I have a 1982 Ford F-150, with a 1978 351w motor in it, the truck orginally had a 302 in it. Right now the motor has flat top heads, and a rv cam in it. It is also bored .30 over. At the moment it has manifolds on it i'm wondering what it will be like if it put headers on it? Power wise? Also i have a 2 bbl motorcraft carb. on it, but I do have a 4 bbl intake for it that i havent put on, what will be the difference if i do put that on? and what carb should i get for it. Also my kickdown rod on it is not hook up at all ? How much will that help...? Also is their anything else to do to get more power out of it?
Michael Goodwin
Michael Goodwin
Installing headers, a weind 4brrl intake and a good 600cfm carb will really wake up your motor. is the rest of the exhaust stock as well? if so you might think about having that redone as well for instance buying a bassani Y pipe and then having a shop fab up a 3" exhaust from there out stock location would be the way to go.
you will have a noticable increase off idle for sure
85 i dont agree with that 2500rpm comment. at least not with this setup or what he mentioned.
dusty2052000
03-20-2006 09:23 PM
tmn8tr
11-10-2002 08:02 PM
