1978 - 1996 Big Bronco
4wd 92 bronco shift problems
Old Nov 12, 2006 | 07:35 PM
texasgoat's Avatar
texasgoat
wont go into low 4wd. put in neutral pressed brake wont engage into low. can hear the swithd sound under dash on 4w high but no sound on low switch change. does not light up either. thanks JIm
Old Nov 13, 2006 | 09:11 AM
Kemicalburns's Avatar
Kemicalburns
sounds like the motor is bad. you may need to take it apart and test with it out.
or look into a manual tcase swap.
