fuel injector wiring problem
Old Nov 9, 2006 | 08:43 PM
cloud_n_axle's Avatar
cloud_n_axle
im in automechanics in highschool and i put my truck in the shop. well we tested the fuel injector lines for power and both sides of the plugs have power when one is supposed to be grounded at least that is what my teacher said i need help figuring why both sides of my plugs have power makin my fuel injecors get 12volts of power
Old Nov 11, 2006 | 01:16 AM
EPNCSU2006's Avatar
EPNCSU2006
Unplug all of the fuel injectors before testing them. With the engine off, there will be 12V on all the wire from where the injectors get their power feed all the way to the injector control pins at the computer when the injector is plugged in because it completes the circuit. Resistance doesn't reduce voltage if there is no current. The only time they won't show 12V at the computer is for the moment that the circuit is grounded (again when the injectors are plugged in).
Old Nov 11, 2006 | 10:39 AM
subford's Avatar
subford
If the key is on and the engine is not running than you will have 12V on both sides of the injectors. The computer grounds one side to fire the injector.
This is just rewording what EPNCSU2006 said and he was correct.
Old Nov 11, 2006 | 12:56 PM
cloud_n_axle
actually i discovered that with another type of tester light that blinks when turned over but not when the key is just on ty
Old Nov 11, 2006 | 02:41 PM
LxMan1's Avatar
LxMan1
That is called a noid light. It will show injector pulse because it happens to fast to see the pulses with a regular test light.
Robert Fisk
31
Nov 26, 2016 04:56 PM
MONAVIERONJON
26
Jul 20, 2016 01:09 PM
mooselovat
Mar 20, 2016 11:15 AM
ChurchBuilder
22
Oct 16, 2006 09:23 PM
nallen731
Modular V8 (4.6L, 5.4L)
13
Oct 16, 2005 12:49 PM
