2006 Explorer noise problem
Old Nov 9, 2006 | 02:19 PM
CRaeNichols's Avatar
CRaeNichols
I recently purchased a used 2006 Explorer with 12k miles (my third Explorer, still under warranty). While driving at all speeds I can hear a rattle noise in the area of the transmission. Noise increases with speed and stops when still. I took it to the dealer for repair. The first time they said it was the muffler & they replaced it. On the drive home noticed noise was exactly the same. Took it back and the second time they said it was the transfer case; eventually they replaced that. On the way home heard the same noise continuing, maybe a tiny bit quieter. Now he says that all '06 Explorers have the same noise/rattle. Is anyone with '06 having similar problems? Does your's rattle all the time?
Any feedback would be appreciated.
Old Nov 10, 2006 | 12:14 PM
Steina's Avatar
Steina
CO River Rat
I'll bet Ford would be REAL interested to hear this service manager is bad-mouthing all '06 Explorers! If he has other '06s on the lot, make him prove it. I know it's a pain but keep after them, and escalate your problem to the next level if you ain't gettin' no satisfaction. This "Oh, that's normal" syndrome is one of the reasons Ford is in trouble right now.
Welcome to FTE!
Steve
Old Nov 10, 2006 | 12:26 PM
pbjohns's Avatar
pbjohns
I would go to another dealer and test drive some of the same trucks. If you find the same sound,ask them, see if the answer is the same. 2 cents
Old Nov 10, 2006 | 01:36 PM
Coastiejoe's Avatar
Coastiejoe
Although many of them do have noisy transfer cases, there has been updates made to the replacements to help with that issue.
I would also go to another dealer, do not tell them what you have had done, simply let them determine the issue based on your initial complaint.
Old Nov 10, 2006 | 02:39 PM
spikedog's Avatar
spikedog
Old Explorers were known to have rattle-prone catalytic converter covers. Hard to think they wouldn't have solved that problem by now.
Old Nov 10, 2006 | 05:59 PM
marragtop's Avatar
marragtop
Maybe a dumb question, but have you checked the heat shields? Also, does the rattle vary with the temperature of the truck? If so, it could be a cat converter baffle,
Old Nov 10, 2006 | 09:35 PM
Buck 1's Avatar
Buck 1
My '06 Explorer has a rattle/noise at about 20mph and sometimes at speeds slightly higher when I hit the gas. Could be a heat shield or some type of cover. Anyone else got an idea?
Old Nov 10, 2006 | 09:47 PM
CTford's Avatar
CTford
Do you have the V6 or V8? If you have the V6, you have the 5R55 tranny. At least in older model years these had torque converter problems- mainly noise. Is it vehicle speed related or engine speed related? This would be a crucial question to answer- if it's engine speed, I'm inclined to think it's somewhere in the tranny- vehicle speed- probably not the tranny.
Old Nov 11, 2006 | 07:57 PM
Buck 1's Avatar
Buck 1
It has the V6, and the noise seems to be vehicle speed related. Only happens at about 20 mph and if you let off on the gas and then hit the gas at other speeds. Sounds like something is loose and vibrating...........
scooter3
Jun 24, 2012 12:37 PM
FE1998
Nov 2, 2008 06:01 AM
Brandivk
Feb 5, 2006 09:39 AM
hdrk2001
Jun 12, 2003 09:36 AM
kymberlyee67
Mar 19, 2003 09:28 AM
