E150 Fuel Cutoff Switch?
Old Apr 5, 2004 | 12:04 AM
Exodus1980's Avatar
Exodus1980
Ok guys, answer me this one:
I was driving down the highway yesterday at 65mph when the old work van suddenly died and rolled to a stop.. uphill no less. The gas tank was about 1/4 full, so I know I didn't run out of gas.
It's a 1988 e150 with the 300 straight 6, fuel injected. I've recently done a full tuneup (new plugs, wires, rotor cap, oil change, all new filters), except that I didn't replace the fuel filter. The sticker under the hood says something about a fuel cutoff switch, which is one of the things I'd like to check tomorrow other than spark and fuel pressure. I have no owners manual to tell me the location of the switch or how to reset it. Does anyone know where to find this switch and how to reset it, or can you point me in the right direction anyway? LOL
Thanks a mil
- Nate
Old Apr 5, 2004 | 06:49 AM
94van's Avatar
94van
Check behind the passenger's side kick panel. Just push the button down to reset.
Old Apr 5, 2004 | 12:03 PM
blue_mule's Avatar
blue_mule
Does it have Dual fuel tanks ?
If so, it is the manual fuel selector valve gone bad. VERY common in 1986-91 vans and trucks.
Old Apr 5, 2004 | 07:03 PM
Exodus1980's Avatar
Exodus1980
nope.. single tank
Old Apr 6, 2004 | 10:09 AM
blue_mule's Avatar
blue_mule
There are 2 pumps on this system. Are you sure the tank pump is working?... the tank pump is low pressure about 5-10 psi. The frame rail pump is higher (not sure of top pressure)... just because you may hear the rear pump come on does not mean that either has ample pressure... If fuel pressure is too low, it will not run.
InfantryCPT
29
Oct 16, 2022 01:33 PM
jimbolina
Jan 18, 2014 07:59 PM
ScottT80
Jul 25, 2013 11:53 PM
DoofusOfTheDay
Nov 28, 2012 04:36 PM
4dfan
Escape & Escape Hybrid
Jun 10, 2011 01:50 PM
