Sponsored by: Real Truck
Replacement steering stabilizer
Old Nov 7, 2006 | 06:40 PM
TheWiz427's Avatar
TheWiz427
I'm looking to replace my steering stabilizer but want to replace it with a decent one. Who has the better stabilizer these days?
Old Nov 7, 2006 | 06:49 PM
mjlevi's Avatar
mjlevi
I just replaced my factory stabilizer with a Fabtech steering stabilizer around $45.00 and that includes the hardware...I believe Rancho has one also at the same price range...and I did notice a slight improvement with the change,..hope that helps !
Old Nov 7, 2006 | 07:07 PM
mgdflee's Avatar
mgdflee
we use to have a fabtech dual system. it worked great. but you have to have a 6inch lift to run it. it barely cleared the tie rod.
Old Nov 7, 2006 | 07:34 PM
TheWiz427's Avatar
TheWiz427
Who has the Fabtech stabilizer? I tried Jegs and Summit.
Old Nov 7, 2006 | 07:37 PM
mjlevi's Avatar
mjlevi
rockymountainsuspension,.....www.rockymountainsusp.com
Old Nov 7, 2006 | 08:38 PM
TheWiz427's Avatar
TheWiz427
Thanks! Thats not a bad price just have to see what shipping is.
Old Nov 7, 2006 | 08:43 PM
ReAX's Avatar
ReAX
I have a bilstien that's soon to replace my factory. So far it seems to be a bolt on, but I need an impact to pull the bolt.
Old Nov 7, 2006 | 10:17 PM
a.s.k.52's Avatar
a.s.k.52
I'm running a skyjacker single, cheap and seems to do the job.
Old Nov 7, 2006 | 11:12 PM
Pocket's Avatar
Pocket
I'm running the Rancho RS5406. It's bigger and beefier than the stock, but it's still a bolt on replacment. Even came with the relocation bracket that replaces the original. On and off road it has worked great.
Old Nov 8, 2006 | 12:11 AM
f18mech's Avatar
f18mech
I just replaced with a monroe. They were the only one I found that was black and ordered a black boot with it. about $40 from NAPA. bolt on replacement.
works great so far. Stock was actually leaking..
Old Nov 8, 2006 | 10:10 AM
TheWiz427's Avatar
TheWiz427
So pretty much they are all the same?
Old Nov 8, 2006 | 02:52 PM
Hootbro's Avatar
Hootbro
I would buy it elsewhere besides Rocky Mountain. I order one from them for my 05 SD F250 and received someone else's customer return stabilizer. All mount parts where there and stabilizer was serviceabile but was missing the decal for the body. Called to Rocky wanted me to return the whole thing on my dime for refund or exchange. I decline and called FABTECH directly trying to get a replacement decal. Was not impressed with FABTECH either as they seemed bothered for such a request for a decal and got the "checks in the mail" response of them sending me a replacement decal. Been 4 months and no decal. Stabilizer does work good though. You will also need to order a seperate boot if you want one as the stabilizer pack does not come with one even as standard.
Another complaint I had with Rocky was that their online ordering is not all that automated. Received no noticed of when item was shipped or tracking info. I ordered the boot the same time as the stabilizer and they dropped shipped both parts from two seperate location with both arriving at seperate times and with no invoice. I received the boot first and thought they totally blowed off my the stabilizer which showed up the next day.
Hootbro
Old Nov 8, 2006 | 04:01 PM
mongo75's Avatar
mongo75
My 99 dually doesn't have a steering stabilizer. Can a stock suspension truck benefit from one?
Old Nov 8, 2006 | 04:11 PM
skirk55's Avatar
skirk55
I purchased Rancho stabilizer and it is about 4 tims the size of a stock one. It also came with a boot. I had a he*& of a time removing it. The Rancho went on easy!
Old Nov 8, 2006 | 07:24 PM
Pocket's Avatar
Pocket
No, some will be a direct replacment and perform as the stock one did. Others will be beefier and help give you the stock feel when running larger sized tires. The single units like the one I have are recommended for up to a 35" tire, which is close to the tire size I'm running. Going up larger in size and it's recommended to run a dual stabilizer setup. On the flip side, running a dual stabilizer setup on smaller tires is overkill, but some find that it looks cool.
