5.0 accessory bracket belt setup?
Old Nov 7, 2006 | 04:10 PM
73FOMO's Avatar
73FOMO
I am putting a late model 5.0 in a '73 pickup. Does anyone have any experience or suggestions on accessory brackets or belt setup. I want to run, ps pump, altenator, water pump, and a/c compressor. Does anyone have any experience with the correct setup for this combo? I have some of the original brackets, not sure if all. that came out of the '92 truck, but I am not running the smog pump. I have the bracket that mounts the ps pump. I don't want to spend a fortune on brackets and pulleys.
Old Nov 7, 2006 | 04:42 PM
HemiEater's Avatar
HemiEater
Take a walk in a scapyard and try and find something that has a 4 hole crank pully with all the acessories(sp) you need and buy it all, shouldn't cost too much. Look for a setup with a small crank pully, can't remember what I got mine from but it had a small crank pully on it, little smaller than the balancer.
Old Nov 8, 2006 | 12:01 AM
crash12884's Avatar
crash12884
how mine was configured was with the ac pump top right ps pump bottom right alternator on the left side ... the ac pump was added afterwards and was huge and a pain to work around ... i would recommend doing that diff prob dropping the alternator and putting it above it to allow easy access to the distributor and as for parts the junk yard would be the way to go it shouldnt cost too much and looking around may give you a better idea of how to do it
Old Nov 8, 2006 | 08:58 AM
TigerDan's Avatar
TigerDan
Did you get this motor without all the accessory drives and have to start from scratch? If it did come with it's original serpentine drives, that's what I'd run. You can buy a different belt from the original and route it differently to run the accessories you want.
Old Nov 10, 2006 | 08:59 AM
73FOMO's Avatar
73FOMO
Yes...I have to start from scratch. I only have the bracket that hold the p/s pump and smog pump, which has long been thrown in the dumpster.
Old Nov 14, 2006 | 10:59 AM
73FOMO's Avatar
73FOMO
Hey...I actually do have both 5.0 brackets. I think I will use these for now with shorter belt to bypass a/c and smog. One bracket holds the smog and alt., the other the p/s pump and ac comp.
Old Nov 14, 2006 | 06:58 PM
TigerDan's Avatar
TigerDan
Okay, that should work. Get yourself a Goodyear Gatorback 4060872 and route it like this:
Old Nov 15, 2006 | 08:00 AM
73FOMO's Avatar
73FOMO
Thanks guys. This helps. Looks like I may need that black steel bracket that is supporting the a/c compressor as well. What type of a/c compressor does Ford use? I plan on using a Sandin. Maybe it will work with this bracket.
Old Nov 15, 2006 | 08:43 AM
TigerDan's Avatar
TigerDan
The one in the pic is a Ford FS6. The truck had a Sandin on it when I got it, but it won't easily fit the 5.0 brackets. The black top bracket wouldn't have fit it at all though. I could adapt the compressor to fit but it had a V-belt clutch and since the 5.0 came with the FS6 compressor with the serpentine clutch, it just made more sense to use it.
Old Nov 15, 2006 | 10:57 AM
73FOMO's Avatar
73FOMO
Ah ha...now I am curious if the FS6 compressor will work with the aftermarket a/c that I plan to install. I plan to use hot rod air.
Old Nov 15, 2006 | 06:36 PM
TigerDan's Avatar
TigerDan
No reason I can think of why ot wouldn't work...although I'm far from what you'd call an expert in A/C.
cadunkle
Feb 11, 2019 09:03 PM
73FOMO
Mar 19, 2014 06:08 PM
first today
General Automotive Discussion
Dec 13, 2010 02:36 PM
wantaford
Feb 6, 2008 10:34 PM
