oval or rectangular ports on heads?
Old Oct 20, 2006 | 11:29 AM
cjben's Avatar
cjben
I am needing to order a set of header gaskets for my '85 351w windsor in my 78f100. when i go to place the order,I need to know if the exhaust ports are rectangular or oval. how do i know this if I don't take the exhaust off? what years were oval and which were rectangular thanks,Ben
Old Oct 20, 2006 | 11:54 AM
loudfords's Avatar
loudfords
I thought oval vs. rectangular was big block Chev stuff. I believe the Windsor exhaust ports were the same (or close) all the way from 60s to 90s?
Old Oct 20, 2006 | 12:37 PM
Conanski's Avatar
Conanski
All the windsor heads have small rectangular exhaust ports. Only the big block stuff has oval ports....
Old Oct 20, 2006 | 08:30 PM
cjben's Avatar
cjben
ok,thanks guys. the summit racing website offers rectangular or oval port gaskets for the 351w,i will go with the rectangular.
Old Oct 20, 2006 | 09:05 PM
TigerDan's Avatar
TigerDan
For some reason they make headers and gaskets with oval ports for these engines, and have for years. I would suppose it's a better configuration for anti-reversion...
Only get oval port gaskets if you have oval port headers (which still fit the rectangular port heads.)
Oh, and there is an oval port head, it's the GT-40P as found on the '97-up Explorer/Mountaineer 5.0
Old Oct 21, 2006 | 08:54 AM
P51D Mustang's Avatar
P51D Mustang
AFR's SBF heads use an oval exaust port too.
Old Oct 21, 2006 | 11:49 AM
Conanski's Avatar
Conanski
I assumed the OP was using factory heads.....
Old Oct 21, 2006 | 04:56 PM
cjben's Avatar
cjben
the heads are stock for a 85 351w HO,so the ports should be rectangular. I will be ordering the gasket set today. thanks for the info every one!!
Old Nov 15, 2006 | 06:07 PM
Fordbyford's Avatar
Fordbyford
Hey there I have a 1996 Ford Bronco 351W EFI auto trans and I have bought a pair of hedman long tubes for it and when they came in today I relized that the ports on the headers are oval and the ports on the cylinder heads are square, do you think I could still use these headers on my application?
Old Nov 15, 2006 | 06:09 PM
baddad457's Avatar
baddad457
Yea, the ports are larger than the head's ports. Not a problem.
Old Nov 15, 2006 | 06:21 PM
Fordbyford's Avatar
Fordbyford
You know where I can buy the right gaskets that will make these seal nice and tight?
Old Nov 15, 2006 | 06:31 PM
baddad457's Avatar
baddad457
Use Headmans gaskets, or try your local Advance Auto, Autozone, etc to see what they stock. I used a set of aluminum "sandwich type" gaskets on mine, don't recall who made em, but they work great and are reuseable. Expensive at 20-something dollars a set, but worth it. Bought em at Autozone I think.
Old Nov 15, 2006 | 06:47 PM
cjben's Avatar
cjben
as baddad457 said,the headers will work,just use oval header gaskets
Blue Oval Beauty
Aug 20, 2015 09:39 AM
Father Donald
Apr 1, 2015 11:13 AM
Quizzack
Mar 14, 2015 11:20 AM
bbf150
Electrical Systems/Wiring
Feb 12, 2015 06:03 PM
checksix
23
Jan 12, 2012 03:01 PM
