Code 760 & 101
Old Nov 3, 2006 | 07:17 PM
Kozak's Avatar
Kozak
Code 760 & 101
A few months back I had a studder and a miss. Turned out to be one of the coils was bad. Had it replaced and the problem went away. A couple of days ago the problem returned for one day, actually for a 60mile trip, then on the return trip it went away (we had a few days of rain and thought maybe something got wet?) The check engine light did not go on (it didn't go one the last time either). I checked the codes and got two 760 and 101. Any ideas? I have a 2001 E350 extended van, with 66,000 miles.
Old Nov 5, 2006 | 09:28 AM
rebocardo's Avatar
rebocardo
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0760 Shift Solenoid C Malfunction
Old Nov 5, 2006 | 11:30 AM
Kozak's Avatar
Kozak
Mass or Volume Air Flow Circuit Range/Performance Problem -
What does it mean? A dirty air filter?
Shift Solenoid C Malfunction -
Again I don't know what to look for. Any suggestions on what I should check?
Old Nov 6, 2006 | 12:41 PM
rebocardo's Avatar
rebocardo
More likely a bad or dirty sensor.
Check the 97-2004 F-150 Forum or engine forum for your van (you did not mention engine size) and ask there. Search first.
Transmission. I would post in the transmission forum. Search first, though I could not find anything for that code there, maybe try some other words. If the solenoid is bad, you probably have to have the transmission disassembled.
Armycop
6.7L Power Stroke Diesel
13
Jan 6, 2015 12:33 AM
Marc S
104
Dec 5, 2011 02:29 PM
Ted Wolf
1997 - 2003 F150
Aug 22, 2005 09:22 PM
Dabar
Aerostar
May 30, 2004 07:59 AM
