98 expedition headlight problem
Old Nov 2, 2006 | 06:58 AM
aptkid1's Avatar
aptkid1
When turn on the switch, headlights will not come on. Tail lights, amber lights, side markers all come on. Also when pull turn signal arm towards me, the headlights come on high beam but when let go of the turn signal arm, the headlights go back off. Any one can offer suggestions to repair.
Old Nov 2, 2006 | 09:43 AM
lwong's Avatar
lwong
Sounds like the low beam filaments are broken in both of your bulbs. Try replacing one of the bulbs. If your low beam comes on in the bulb that was replaced, then that's your problem.
Old Nov 2, 2006 | 10:11 AM
raykjavik's Avatar
raykjavik
Did you check the Fuse?
Old Nov 2, 2006 | 10:28 AM
aptkid1's Avatar
aptkid1
Thanks for responding. Yes, checked fuse and relay.Replaced the relay just in case. Any other thoughts
Old Nov 2, 2006 | 10:30 AM
aptkid1's Avatar
aptkid1
Thanks for Info. Will try that today. Interesting that both filaments would go out at the same time
Old Nov 14, 2006 | 10:13 PM
gyjr's Avatar
gyjr
It's probably your multi-function stalk. I had to replace mine. The problem will get worse to the point the headlights won't come on without jiggling the stalk.
Old Nov 15, 2006 | 08:12 AM
aptkid1's Avatar
aptkid1
Thanks for your info.
Old Mar 1, 2007 | 12:47 PM
rol1's Avatar
rol1
My daughter-in-law's 97 Expedition has the same problem.
The switch is in the dash to the left of the steering colum.
Could the dimmer/turn signal lever still be the culpret?
Do any of you guys have a factory service manual for a 97 expi that could tell me where and what color wires I shoul check to troubleshoot this problem?
I have a $4 computer safe LED test light by Powercraft from Checker.(funny that the old type with bulbs that are not computer safe cost almost twice as much)
Old Mar 1, 2007 | 01:09 PM
AT79's Avatar
AT79
i had the same problem with mine,theres another switch in the steering column it could be dirty.try pulling the cover off and blowing it out with a can of air like the ones you use on computer keyboards.
Old Mar 1, 2007 | 08:52 PM
AdamSmith's Avatar
AdamSmith
FOR 97-98 EXPEDITIONS
12 VOLT CONSTANT YELLOW (+) and LIGHT GREEN/PURPLE (+) IN IGNITION SWITCH HARNESS
STARTER RED/LIGHT BLUE (+) IN IGNITION SWITCH HARNESS
IGNITION 1 BLUE/LIGHT GREEN (+) IN IGNITION SWITCH HARNESS
IGNITION 2 RED/BLACK (+) IN IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 1 GRAY/YELLOW (+) IN IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 BLACK/LIGHT GREEN (+) IN IGNITION SWITCH HARNESS
PARKING LIGHTS ( + ) BROWN (+) @ HEADLIGHT SWITCH
POWER LOCK PINK/YELLOW (TYPE B) @ KEYLESS ENTRY MODULE, See NOTE *1
POWER UNLOCK PINK/LIGHT GREEN (TYPE B) @ KEYLESS ENTRY MODULE
LOCK MOTOR WIRE PINK/BLACK (+) IN DRIVERS KICK PANEL
DOOR TRIGGER LIGHT BLUE/WHITE (-) @ KEYLESS ENTRY MODULE
DOMELIGHT SUPERVISION BLACK/LIGHT BLUE (+), Requires Part #775 Relay IN PASSENGER KICK PANEL
HORN DARK BLUE (-) @ STEERING COLUMN HARNESS
TACH WHITE/PINK @ ENGINE HARNESS
BRAKE LIGHT GREEN (+) @ SWITCH ABOVE BRAKE PEDAL
ANTI-THEFT FORD'S PATS ANTI-THEFT TRANSPONDER SYSTEM TRANSPONDER @ IGNITION SWITCH TUMBLER
phillips91
General Automotive Discussion
Apr 21, 2020 11:13 PM
three.on.the.tree
21
Apr 21, 2016 06:36 PM
B-Rad31302
Nov 10, 2015 02:04 PM
weblawdog
May 15, 2015 12:11 AM
GubNi
Oct 19, 2009 08:21 AM
