ok, someone help me settle this debate
Old Nov 2, 2006 | 11:55 AM
Car_nut57's Avatar
Car_nut57
FTE *******
The surge under load will occur when the trucks air flow has been altered and the computer chipped for more performance because it creates a situation where the turbo is out of its performance curve. This has to do with exhaust drive pressure on the turbine side of the turbo verse the compressor side. When the compressor side has enough pressure (boost) to overcome the exhaust back pressure (drive pressure) on the turbine, then the turbo slows down and boost pressure can flow backwards towards the intake. Once the pressure on the compressor is reduced in relation to the drive pressure the turbo spools forwards causing the other half of the surge. The compressor wheel or housing reduce the drag on the compressor side thus solving the problem.
Old Nov 2, 2006 | 12:01 PM
crack's Avatar
crack
ahhhh, its starting to make sense in my simple mind now. thanks Car_nut
Old Nov 2, 2006 | 12:07 PM
never2big's Avatar
never2big
Yes thanks guys, I have this same problem on my 03 and Im debating on which method I will use. I am leaning towards the WW. I had some questions about theory as well and this thread explained it. You guys are great!
Old Nov 2, 2006 | 03:05 PM
Pocket's Avatar
Pocket
The I guess all the sites selling it are lieing. They all advertise the following:
* Increase Airflow
* Lower Exhaust Temperatures
* Increase Low-End Throttle Response
* For use in 1999.5 - 2003 7.3L Ford Powerstrokes
David they are kinda true:
At lower rpm's it spools up faster and does move more air quicker but it will typically produce 2-3psi less boost at the topend and this is where the lower EGT's come in
JTHarvey has helped me in the past understand some of this, and I did some more looking into it as well when I was trying to decide what to do about my turbo setup.
The way I understand it is that the WW overall is less efficient than the stock compressor wheel, because of every other vane is halfed. The advantage that the WW does have over the stock is that with the design of alternating blade sizes, it actually "cuts" into the air better at lower rpm's, which is why you have a quicker response in the low end. The efficiency range of this is cut short at higher wheel speeds, which is why you actually lose boost on the top end.
In other words, as the compressor wheel spins slower, the large and small blades grab the air better than a wheel with all equal length blades But as the wheel speeds up, the smaller blades lose the ability to grab air on the WW.
Old Nov 2, 2006 | 06:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I just spent a half hour thinking and typing my viewpoint. I went to enter it, and the error 404 message came up. I went to hit back to retrieve what i wrote, sure enough it wasn't there. I have my opinion to voice but obviously im pretty heated and it's not going to be for a while.
Old Nov 2, 2006 | 08:11 PM
crack's Avatar
crack
although that is unfortunate, its still pretty funny. but I would like to hear whatyou have to say.
Old Nov 2, 2006 | 08:59 PM
white Buffalo's Avatar
white Buffalo
If you have the $400 get the ATS housing. Many folks say the WW will cure 99% of the surge so I went this route for less than $100 and the ATS housings was back ordered at the time. Has worked well for me and have'nt had any problems towing my 9,500 lb 5th wheeler.
The van turbo can have a bit of lag at the low end so I figured the WW would help out since it's supposed to push more air at the low RPM's. Not sure if my reasoning is correct but I like how she runs and I can haul a$$ down the interstate with Tony's tow burns & the 5th wheeler.
Keep the Rubber Side Down!!!!!!!!!!!!!!!!!!!
Full throttle untill you see God - then brake
Its not speed that kills - it's the sudden stops
(my favorite) Dip me in honey & throw me to the lesbians!
Old Nov 2, 2006 | 09:15 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Kris, that sucks but we've all had it happen. When I get a lengthy one going and have spent quality time, I always hilight and copy before submitting. Been there done that. Easy recovery.
Now all this talk about a WW performing better down low does not seem to jive with what I recall. I thought low end was lost with it and those half teeth grabbing away. And how could it spool up any quicker when the drive pressure from the exhaust turbine is controlling that? I thought all of the benefits of the WW were the lack of boost capability producing less surge and flutter when getting it on going down the road? Thoughts?
Edit: Kris, I've not been able to find the 404 error code in the manual. I recommend checking the CPS or Computer Position Sensor. A common malady on the 7.3 Diesel forum. Symptoms include loss of data, slow to load, and access denied or server not available messages.
Old Nov 2, 2006 | 09:19 PM
white Buffalo
I hear ya Tenn,
What we should probably do is get a few (maybee 3 or 4) cases of beer a chalkboard and a bunch of cigars, by the end of the night we can get it all figured out.
Might not remember in the morning though.....
Old Nov 2, 2006 | 09:26 PM
Tenn01PSD350
You got it Rich. Who wants to remember anyway. It's a new day.
PowerstrokeJunkie
youre on fire tonight, that was great! i was thinking WTF is he talking about, error 404+CPS=? Then i looked and ha i got it. Youre too funny. Maybe i should get a Blue Computer Position Sensor.
Or how about just a new one.
Old Nov 2, 2006 | 09:28 PM
Tenn01PSD350
Kris, dare I say, I hear they sell them on Ebay for about $60?
Edit: I think JT hit it earlier with his fan analogy but I am very interested in your thoughts so please post them.
Old Nov 2, 2006 | 09:30 PM
  #28
empiretc's Avatar
empiretc
Arrow
Dude, always copy to the clipboard when you have that much dedication in a post. YOu can loose internet connection at any time, but atleast you can paste and save. Beats the hell out of typing it all over, and your never going to say it exactly the same again.
With that said, I really would like to hear this heated opinion you have as my wife is thinking this WW thing is an affordable xmas gift I will really like (she overheard me talking about it with my pops).
  #29
white Buffalo
If it's at Guntersville Lake I guess we'll also need fishin equipment & a boat. Oh, and we better invite Bama-sixguns. Kris - you gonna drive down & get out of the snow?
Old Nov 2, 2006 | 09:32 PM
  #30
Tenn01PSD350
Rich, if we go to Bama, I will be bringing my boat. We gotta make that happen sometime.
