Which tranny do I have?
Old Nov 1, 2006 | 04:41 PM
artfuldodger's Avatar
artfuldodger
In order to change the Tr. Fluid I need to know what tranny to buy a filter and gasket for. There are two;the 4R70W and the E40D. I know this is coded on the door tag but what are the codes? Also, I need to know what rear differential I have; a 9.75" or a 10.25" so I know how much friction modifier to add as per instructions in the Haynes manual, page 1-2. Thanks guys in advance. I know you'll deliver the answers.
Old Nov 1, 2006 | 05:16 PM
FTE Herman's Avatar
FTE Herman
What year make/model do you have? Also, what engine and whether you have 4WD. I think your choices are eithe 4R100W or R70W. I didn't know they used E4OD's.
Old Nov 1, 2006 | 07:01 PM
artfuldodger
artful adds:
Further to my questions regarding tranny and differential, my expy is a 2001 4X4 5.4 L, E.B.
Old Nov 1, 2006 | 08:16 PM
aagitch's Avatar
aagitch
You should be able to crawl underneath your rear differential and see a tag on it. should tell you what it is
Old Nov 2, 2006 | 08:18 AM
Johnny Langton's Avatar
Johnny Langton
Look at the door tag on your expedition-the sections listed as axle and trans will have one of the build codes listed below:
JL
19 — 3.55, non-limited slip (Expedition/Navigator).
17 — 3.31, non-limited slip (Expedition/Navigator).
H9 — 3.55, limited slip (Expedition/Navigator).
H7 — 3.31, limited slip (Expedition/Navigator).
H6 — 3.73, limited slip (Expedition/Navigator).
Transmission Codes
U — Automatic 4R70W (Expedition/Navigator).
E — Automatic 4R100 (Expedition/Navigator).
Old Nov 2, 2006 | 12:23 PM
99phxexp's Avatar
99phxexp
What kind of limited slips are installed in ford rearends? I have the H9 code
Old Nov 2, 2006 | 06:53 PM
FTE Herman's Avatar
FTE Herman
Ah Johnny, ya took all the fun out of it!
99phxexp - all limited slips are clutch type.
nashvegas99
Feb 17, 2017 06:56 PM
Duderoy
15
Nov 19, 2016 12:03 PM
erick wireman
Mar 8, 2015 11:56 AM
92will
Jul 28, 2011 08:28 PM
s_laviolette
Apr 5, 2002 08:49 AM
