Ned to identify axle code
Old Mar 31, 2002 | 04:47 PM
s_laviolette's Avatar
s_laviolette
Hi
I cant find what axle code 12 is.. anyone know ? ( for 1990 f150 2x4 with mazda tranny )
thanks !
Old Mar 31, 2002 | 04:50 PM
figueiredo1224's Avatar
figueiredo1224
>Hi
>thanks !
DOes any one know what the metal that is used for the front i-beams is, cast steel, iron or forged... email me at sfigueiredoNo Email Addresses In Posts!,
I have a 91 chassis for my 66 f100 that I am in the process of making a new suspension from the ground up and I am going to have the ibeams welded for better angle etc.
Old Mar 31, 2002 | 05:21 PM
mantta's Avatar
mantta
My shop manual does not list an axle code 12. it lists a 13 as 4.11, a 14 as 3.00, a 16 as 3.50, a 17 as 2.47, a 18 as 3.08 and a 19 as 3.55.
Old Mar 31, 2002 | 09:17 PM
riffraff's Avatar
riffraff
I found listing that states a code 12 to be a 2.73 ratio. Not sure if this was a front or rear, or if it even makes a difference. 2.73 seems to be a bit low for a truck.
Old Mar 31, 2002 | 10:05 PM
DeGideo's Avatar
DeGideo
In my 1994 F-series owner's manual axle code 12 is listed as a rear axle 2.73:1 ratio,non-limited-slip.It should be a 8.8" Ford axle with a 3,800 lb. capacity rating.
Old Apr 2, 2002 | 02:44 PM
Rockstar's Avatar
Rockstar
2:73 with a Mazda 5 speed tranny? That cant be, you would be doing 60 in first gear. I geared up my truck from 3:55 to 3:08 do to rear end blowing out. I have to down shift damn near every hill i klimb. I run 60MPH at 1800 RPMS.
Old Apr 5, 2002 | 04:39 AM
s_laviolette
I find it hard to believe myself... i get to 2000 rpm at 10 mph and have to shift to 2 nd, now i put on 31' tires, like i can got up to 15 mph but I have a harder time to get to 65 mph, at 60 mph i get 2000 rpm on 5th.
What would be my best be to get great accelaration and higher top speed if i stick with 31's ??
thanks
Old Apr 5, 2002 | 08:28 AM
Rockstar's Avatar
Rockstar
[updated:LAST EDITED ON 05-Apr-02 AT 09:31 AM (EST)]I would find some 3.55 gears, If you still have to down shift to pass someone 4th will have plenty of power. Before my 3.55 blew out, I could bury the speedo.(it took a while) Now with 3.08 I can't get 80 out of it. The 3.08s were made for the 4-speed trannys with the granny first gear. With my stock tach, it seems our RPMs are close, you are probably running a 3.08. If all else fails pull the cover off and count... I have an 88 F-150 300-6 5-speed 4X4(might be different)
Good Luck!!!!
Old Apr 5, 2002 | 08:30 AM
mantta's Avatar
mantta
I have 3.55 gears, AOD with standard size tires and at 2000 RPM I am doing 70 MPH.
Old Apr 5, 2002 | 08:49 AM
andym's Avatar
andym
shamp
May 1, 2010 04:03 PM
cgartly
Apr 11, 2008 06:44 PM
jrsroadhauze
Jan 6, 2006 02:50 PM
cannonfodder
Jul 19, 2004 09:50 AM
jamess67
1997 - 2003 F150
16
Dec 28, 2003 09:12 PM
