Help Please!!!
Old Nov 2, 2006 | 12:23 PM
EPNCSU2006's Avatar
EPNCSU2006
What does the TPS have to do with idle speed?
If the closed throttle TPS voltage is above 1V, it will idle too high. This is common knowlege among the mustang guys, and I've experienced it myself.
Cleaning the throttle body is a no no. You have to replace them, these throttle bodies must not be cleaned inside the bore, as this cleaning will impair the sensitive coating.
That's completely not true. Yes there is a coating, but most, if not all the new cleaners labeled specifically throttle body cleaner is coating-safe. The older carb and choke cleaner may remove the coating, but so what? It just means you might have to clean it more often as the coating is there to prevent build up (which it obviously hasn't done its job if the throttle body needs cleaning). It's pretty stupid and wasteful buy a new throttle body simply because the old one is dirty.
Ryan, I'm glad you got your truck back to working like normal! Have a great time camping.
drilling4gold
Jul 16, 2012 10:22 PM
DRRXR
44
Nov 28, 2011 06:25 PM
Heart of Dixie
1997 - 2003 F150
Apr 10, 2009 01:52 AM
fuelman
Dec 16, 2008 09:17 PM
yardbird
Modular V8 (4.6L, 5.4L)
Sep 2, 2004 06:47 PM
