390 Power Problems
Old Oct 26, 2006 | 10:06 PM
JWadeSchutt's Avatar
JWadeSchutt
390 Power Problems
I have a 390 bored out, racing cam, C-6 Trans. w/ a shift kit, all new electrical, and a 600 cfm holley 4 bbl carb to top it off. For what has been done to it, it seems really s...l...o...w. Does anyone have any suggestions of what i could do to make this thing a beast?
Old Oct 26, 2006 | 10:21 PM
Hypoid's Avatar
Hypoid
First, welcome aboard!
This is a big site with more resources you can take in at once, check out the FE forum as well: https://www.ford-trucks.com/forums/forum51/
There are guys there who have forgotten more than I'll ever learn! LOL
What gear ratio does it have in the rear differential?
Old Oct 26, 2006 | 10:37 PM
JWadeSchutt
Im pretty sure they are stock.
Old Oct 26, 2006 | 10:59 PM
JWadeSchutt
I found out that they are 3.27 gears.
Old Oct 26, 2006 | 11:21 PM
85e150's Avatar
85e150
Sounds like you have one of those 7.5:1 compression motors.
What CR do you have? If you don't know, what piston and head? Some combos yield dismal CR, which, in turn, yields dismal power.
Exhaust manifolds? You running those flat-against-the-head stockers? You can cram all you want in, but it has to get out, and 390s have, on some models, the worst manifolds ever produced.
Old Dec 16, 2007 | 08:30 PM
bawstenbilly's Avatar
bawstenbilly
are 8 cylinders firing? Comp test? plug wires arcing?
Old Dec 16, 2007 | 09:36 PM
convincor's Avatar
convincor
600 is not enough. go 750.
what cam? what intake?
Old Dec 17, 2007 | 12:37 AM
Danger_Dave's Avatar
Danger_Dave
600 is plenty. almost too much. 750 would be way over carbureting that motor. maybe it is running too rich or too lean? if you are looking for optimum performance you might want to consider upgrading your ignition system and ditching those points. and a good set of headers will definitely help out. a big bad classic american v8 needs to exhale. like bill clinton. a 390 is no joke and when running right it should really romp and push you back in the seat. my 360 is nasty.
Old Dec 17, 2007 | 06:34 AM
jowilker's Avatar
jowilker
Hey guys, slow down, this thread is more than a year old.
John
Old Dec 20, 2007 | 07:34 PM
baitmaster's Avatar
baitmaster
What "racing cam" do you have, and bored to what?
Brock_Samson
23
Sep 18, 2021 06:19 AM
mike390
Aug 10, 2004 02:08 PM
f1001970
Jan 10, 2004 11:38 PM
wrestler157
19
Jun 15, 2003 10:33 PM
big block power
Sep 3, 2002 02:30 PM
