back with pcm codes, what are they
Old Oct 26, 2006 | 10:47 AM
cathlabdog's Avatar
cathlabdog
codes P403 , P405 , P603 , P1000 , tuner reads these codes but does not give much of a description , should i go to the dealer with them ? truck needs a update reflash supposedly , thanks for any help.
Old Oct 26, 2006 | 10:55 AM
catalinagoose's Avatar
catalinagoose
P0403 is EGR Control Circuit fault
P0405 is EGR Sensor A Circuit Low
P0603 is a Keep Alive Memory code probably caused by your tuner, same with P1000
If you're under warranty, you should take it to your dealer for the EGR circuit issue.
vloney's Avatar
vloney
403-405 are egr codes-603 is loss of kam(get it when you install a tuner) 1000 is obd2 drive cycle not performed yet
Old Oct 26, 2006 | 10:58 AM
cathlabdog's Avatar
cathlabdog
Red face
thanks guys , guess i have to take it to the dealer after all
awillo0406
20
May 7, 2013 02:58 PM
cdiddy
Oct 4, 2007 08:12 AM
sneak
Jan 24, 2006 09:09 PM
Ultramagdan
1997 - 2003 F150
13
Jun 27, 2005 10:10 PM
joycat1
Modular V8 (4.6L, 5.4L)
Jan 26, 2004 12:02 AM
