What did I do wrong? Code P1443
Old Oct 25, 2006 | 08:03 PM
apollo95's Avatar
apollo95
Okay, so my CEL came on with the typical P1443 code on my '95 2.3 5speed 4cyl with 135k on it. I replaced the PCV valve and the Cannister valve assembly (the whole assemby: Ford Part # F57Z-9C987-AB). MY CEL is still on! I took it for about a 10 mile drive and it won't shut off! The only thing I can think of what that I didn't disconnect the negative battery cable when replacing the parts. Could that have something to do with it? HELP!!!
Thanks!
Dave
Old Oct 25, 2006 | 08:07 PM
eigenvector's Avatar
eigenvector
The code won't go off on its own, you have to clear the computer. It is always a good idea to remove the negative cable when working on a part with a sensor hookup - it erases bad data from the computer. But as to the code, you have to clear it with the scanner.
Old Oct 25, 2006 | 08:21 PM
apollo95's Avatar
apollo95
So does this mean that even if I disconnect the battery cable and leave it off for 30 minuts, after about 20 miles or so of driving, the CEL will come back on?
Old Oct 25, 2006 | 10:11 PM
super 6.8's Avatar
super 6.8
That will only happen if you haven't fixed the problem.
jamest1969
Feb 26, 2010 07:28 AM
stupid red ranger
Aug 11, 2004 03:58 PM
hreed
Feb 21, 2004 12:06 PM
Roguespirit
Oct 10, 2003 12:00 AM
timdco
Apr 11, 2003 11:53 PM
