Heating Problem
Old Oct 24, 2006 | 02:10 PM
dlbrummels's Avatar
dlbrummels
Heating Problem
I have a weird issue on my 97' Ranger vith 4.0 V6.
The engine is in the very low end of the tempeture gauge when running, the tempeture control puts out the same amount of heat on the hot side as does on the cold side.
Old Oct 24, 2006 | 09:58 PM
BearMan54's Avatar
BearMan54
Question
Same here on '99 Ranger with 4.0 V6..... Any one know what's going on please let us know, it's getting cold here.....
Thanks
Old Oct 25, 2006 | 06:37 AM
dlbrummels's Avatar
dlbrummels
Heating Problems
Further investigation, I find that the heat stays on through all the different settings, from AC to defrost, with no tempeture adjustment. Max AC works the AC fine, all the rest just produce heat, uncontrolled.
Old Oct 25, 2006 | 06:46 AM
PSKSAM2's Avatar
PSKSAM2
Welcome to FTE!
That sounds like a blend door / actuator issue. Could be seperate from your low temperature gauge issue. Search this forum for "blend door" and you'll get a million threads back. Or click here for a quick description of the common problem, the diagnosis, and the "cheap" fix for a broken blend door.
Ford Explorer Blend Door Fix
As to the low temp gauge, I think the quick things to check are fluid level and the thermostat. If your thermostat is broken open or if a previous owner removed it (or put in a lower temperature one), it won't maintain the engine at the proper temperature.
-Jim
Old Oct 25, 2006 | 06:56 AM
dlbrummels's Avatar
dlbrummels
Heating Problems
Thank you for the quick reply !
Old Oct 25, 2006 | 07:17 PM
BearMan54's Avatar
BearMan54
Wink Update.............
Well guys, I installed a Motorcraft thermostat today and I now have good heat and the temp. gauge is mid way up, just like it should be..... That was one costly thermostat, but it sure was worth it.....!!!
Thanks for the help...........
Old Oct 25, 2006 | 09:11 PM
PSKSAM2's Avatar
PSKSAM2
Glad to hear that you fixed your problem. Motorcraft parts can be pricey, but they can have their benefits as well. You can check out our forum sponsor (Discount Ford Parts) in the future, perhaps you can save a few bucks.
Out of curiosity, was your thermostat busted open, or a too generic replacement running at a lower temp?
-Jim
Old Oct 25, 2006 | 09:29 PM
BearMan54's Avatar
BearMan54
-Jim
It was a Motorcraft thermostat that was in it, the truck has 121,500mi. & I'm betting it's been in there the whole time.... And yes, it was stuck open.... I used the Motorcraft part because of all the threads I'd read about having to go back & install another one because the new one was faulty.......
Old Oct 26, 2006 | 10:21 AM
dlbrummels's Avatar
dlbrummels
You can always test the thermostat by heating some water on the stove to the listed temperature to see if it opens before installation.
Old Oct 26, 2006 | 02:31 PM
BearMan54's Avatar
BearMan54
Yes I know that, but I still wanted to be sure & get a quality thermostat and there's all the difference in the world in the way the Motorcraft part is made......!
HENDEL JR
Jan 7, 2006 11:19 PM
HENDEL JR
Dec 29, 2005 12:51 AM
HENDEL JR
Dec 23, 2005 07:39 AM
