I have a 1089 F150. The turn signals don't work. Fuse is good and so is the flasher. I'm thinking it's the turn signal switch on the stearing column. Just checking to see if this sounds right.
Do not forget you have two flashers down there, make sure you check the right one.
If you pull out the hazard switch see if the flasher in question is clicking. If the one you think is turn is clicking then you have the wrong one.
Also see if all of four of the bulbs flash while you have the hazard switch pulled out. Also the dash signal bulbs.
I don't know what fixed it. Maybe it was me beating on the stearing wheel or yelling at the dash board. Possibly pushing and pulling on th turn signal lever like a mad man. I wish I knew.
