camber
Old Oct 24, 2006 | 05:58 PM
mab6680's Avatar
mab6680
camber
I just rebuilt the front end of my 2000 xls 4WD 4.0L. I replaced the
shocks, ball joints, wheel bearings, end links and an inner tie rod. I
also raised the front by about a 1/4 inch via the torsion bars. When I
went to get a alignment they told me the right side camber was off by -1.
he told me that a camber kit for the right side was sold. I have looked
online for this kit with no luck. Has any one ever heard of this kit and
know where to buy it. I have only found the replacement camber caster kit
that are for the left side. Any help would be great. Thank you
Old Oct 25, 2006 | 09:48 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Rockauto.com has them. They are Moog kits consisting of an oblong washer that replaces the flat washer on the control arm. These are camber-only kits, and are the same for both sides.
For caster adjustment you'll need an adjustable upper control arm/ball joint that fits on the right side. Moog makes them, but I think you have to specify that you need the adjustable one......
A caster adjustment probably isn't necessary unless it pulls to one side.....
Old Oct 26, 2006 | 05:27 PM
mab6680's Avatar
mab6680
i found the moog kit at my local parts dealer thank you
Tabaker
Apr 11, 2021 08:17 PM
mackdog
Mar 6, 2012 09:23 PM
vbxt
Jul 26, 2011 09:16 PM
garvicmos
2004 - 2008 F150
Mar 7, 2009 09:32 AM
