Proper Idle RPM
Old Oct 24, 2006 | 12:27 PM
mwf150's Avatar
mwf150
Proper Idle RPM
Fully warmed up to operating temperature, what is the proper rpm at idle, in park, and in gear for a 2006 F150, 4.6 liter V8 (2V), w/ 4WD & Automatic trans (w/ all accessories off, if that matters).
Thank you.
Old Oct 24, 2006 | 12:29 PM
Lawson4x454's Avatar
Lawson4x454
Mine idles around 600. I guess that's normal.
Old Oct 24, 2006 | 05:54 PM
Bob Jusnes's Avatar
Bob Jusnes
should be between 600 and 650
Old Oct 24, 2006 | 06:17 PM
spiggy769's Avatar
spiggy769
Around 600 is correct...mine sometimes goes as low as 580
Old Oct 24, 2006 | 06:21 PM
whitecrystal1's Avatar
whitecrystal1
580? How in the heli can you tell?
Old Oct 24, 2006 | 07:45 PM
Cavtrooper06's Avatar
Cavtrooper06
Couple ways you could tell:
1) Edge Evolution
2) Hold the trip counter button while starting the truck up, then once started press the trip counter until the RPM's display.
Holding the button down during start up enables the test mode to come up and will last as long as the truck is on. So next start up it'll be back to normal.
Old Oct 24, 2006 | 08:20 PM
whitecrystal1
1) Edge Evolution
I have an Edge and never thought about that. I set the display on temps when I got it and haven't changed it since.
Old Oct 24, 2006 | 08:44 PM
TRX250R87's Avatar
TRX250R87
Rpm
You can also adjust your rpms with the Edge Evolution, but only higher than stock, not lower.
ERIC
Old Oct 25, 2006 | 02:41 PM
spiggy769's Avatar
spiggy769
I used my secret Powers.....I thought everyone had them
Actually just as Cavtrooper said but in reverse..I first set the Trip computer to Diagnostic then when I got the Edge I just have the RPM on always ...mainly cause I do not have the RPM guage due to havin an STX.
Old Oct 25, 2006 | 08:48 PM
whitecrystal1
[QUOTE=spiggy769]I used my secret Powers.....I thought everyone had them
[QUOTE]
May the force be with you.
Old Oct 25, 2006 | 09:16 PM
mwf150's Avatar
mwf150
Wink Idle RPM
Thanks to all for your replies. I too got 600 RPM, warmed up, and in park. It's around 525 in gear. That just seems low, but it must be OK if ya'll are in that ballpark. The dealer wouldn't tell me the spec. I used a laser based stobe with reflective tape on the harmonic balancer ring - a common practice in vibration analysis.
I was fishing to see if maybe my RPM was too low, and tied to the vavle train ticking nosie, which dissipates a few RPM above idle, as if a few more PSI or GPM of oil with the increased RPM clears the lifter tapping.
Am I nuts?
Thanks again.
Old Oct 25, 2006 | 09:20 PM
whitecrystal1
Am I nuts?
Thanks again.
Are you sure that ticking noise isn't coming from the Cam Phaser? There is a tsb for that. That ticking noise also goes away with a slightly higher rpm.
Old Oct 28, 2006 | 07:51 AM
mwf150's Avatar
mwf150
TSB's 05-15-8, and 06-4-7 apply to 3V engines. I have not uncovered a similar TSB for the 2-valve engines. Have you?
Old Oct 28, 2006 | 08:14 AM
whitecrystal1
Oops, I forgot it was only for the 5.4.
Old Oct 28, 2006 | 08:38 AM
mwf150's Avatar
mwf150
The 4.6L motors are also covered in those TSB, but the key is the 3-valves / cylinder feature, rather than the conventional 2-valves / cyl config.
Nevertheless, thank you very much for responding.
Other than the idle tick, I love the truck - ride quality, sound system and creature* comforts for a so-called bare bones model. Then again, the comparison datum is my previous truck - an '87 GM C10 4WD.
Yours truly,
*F150 Creature
My Nightmare
Jun 30, 2016 12:47 PM
cougfan87
May 14, 2016 02:32 PM
sjl2569
1983 - 2012 Ranger & B-Series
Apr 2, 2016 09:27 AM
EMC V10 X
Modular V10 (6.8l)
Dec 31, 2010 06:39 PM
4caster
Aug 9, 2009 04:43 AM
