How much $$ to clean EGR ports?
Cleaned EGR ports
I had to clean my egr ports because my check engine light was on. I was getting code p0701 (low egr gas flow). Unplugged the battery for 30 minutes to reset the computer. Hasn't come on since. Took an hour to do and 2 cans of carb cleaner. Parts cost me about $20 total if you include the carb cleaner. I replaced the Throttle body gasket, intake gasket, and EGR valve gasket. While I was there I went ahead and replaced the egr valve($90) as well but wasn't necessary. The EGR ports were 100% clogged with 80000 miles on the engine. Do it yourself and save the money. I am no mechanic and it was a piece of cake. Have 200 miles on engine since I did the cleaning and runs great with no engine light on yet.
Eric
Eric
Do it yourself.....it's really easy. Start at the air filter and remove everything to the top of the engine, just reassemble everything the same way you took it apart.
Clean anything that has carbon on it.
I do mine about every 75k miles and I've never had any issues. My truck now has 261k miles on it.
capnbass91
02-16-2017 03:14 PM
Ken Blythen
35
06-11-2013 01:57 PM
