Okay...not the 302 I thought I had
I recently have been asking questions about the 302 I got from the junk yard out of an 84 mustang. Well I read the numbers on the block and heads....Its a 69 block from a fairlane or torino and the heads are "truck heads" from around the same year, weird huh. Would this engine be stronger than a newer 302 block? It hasn't been bored out or anything
My info says the heads were originally cast as '69 truck 302 heads with 58cc combustion chambers. The block was a '69 Torino block!! But is it a 302 or 351 block? The deck height is measured from the crank center line to the cylinder head mating surface. The 351 measures 9.48" vs the 302 which is only 8.2". You can also tell by looking at the distributor mount. If it's nearly level with the intake mating surface then it's a 302 block, if it's about 1.5" below the intake mating surface it a 351. Either way. these blocks are heavier than the later blocks and as a result somewhat sturdier.
I just measured from the center of the crank to the head mating surface and got 8.2 so it is a 302. I checked The heads again and they have a "C" on them, I didn't see it before so they are "C9TE-C" heads. I looked in my book I have to determin parts and "C9TE-C" truck heads have a 69cc cumbustion chamber...wow thats big right? The valve size is int. 1.78 and exh. 1.45
C9OE isn't neccessarily a 302 block from a 69 Torino. That's the car line the engineering costs were assigned to. It could have been installed in any Ford or Merc from that year forward. I believe the C9TE heads were 59 cc, not 69.
Originally Posted by reed1951
...... I looked in my book I have to determin parts and "C9TE-C" truck heads have a 69cc cumbustion chamber...wow thats big right? The valve size is int. 1.78 and exh. 1.45
Your going to want a static compression of about 10:1 with a large duration (good sounding) cam.
You may not be able to mill enough, if they are 69cc, and if you use flat tops. Usually it's about a 1cc reduction per eight thousands of material removed.
It's the same with the popular E7TE heads on late model Windsors. Technically it was originally cast by the truck division, but they were found on engines in many of the cars of that era such as the Crown Vic, Mustang, and Lincoln models. The result is.. the casting numbers will tell you the basic parameters of the casting and when it was first produced, but it won't tell you what cam and pistons are installed, or what year vehicle it came from. An original motor would have a metal tag under a bolt head with that information, similar to what you find on a differential.
The books I've seen list the C9TE head as having 58 cc chambers. And the final compression ratio also depends on what flat topped pistons you use. Not all have the same pin height. That varies from 1.585 to 1.610, depending on the piston. That .025" difference is enough to vary the ratio by a full point or better.
old farmer
Nov 7, 2014 02:09 PM
drileybond
26
Jan 15, 2012 12:38 AM
drileybond
Jan 5, 2012 06:54 PM
hipockets9
17
Mar 8, 2010 11:40 AM
RicksF100
Feb 20, 2005 05:57 PM
