Square Driveshaft
Old Oct 22, 2006 | 03:13 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
Square Driveshaft
On an episode of spike tv's extreme 4x4 they fabricated a square drive shaft. They used two sections of square tubing one slightly smaller than the other to slip inside the larger peice of square tubing. then they welded the yokes to the two pieces of square tubing somehow,
i was wondering if anyone has tried this and if so how well did it work, it seemed like a cheap and easy way to make me a front driveshaft instead of paying somone to lengthen mine,
thanks, Nick
Old Oct 22, 2006 | 04:50 PM
havi's Avatar
havi
I'll have the Roast Duck
not roadworthy
Old Oct 22, 2006 | 10:19 PM
quadzjr's Avatar
quadzjr
i planed on making it for the front only, the back i already have?
Old Oct 23, 2006 | 11:08 AM
jim henderson's Avatar
jim henderson
When I was in engineering school, they had some classes on strength of tubes and rods. Turned out that a round tube had quite a bit of strength, almost as much as a solid round rod when it came to torsional stress.
It has been years, but I think the weakness of the square tube is that it has 4 corners where stress under torsion(twist) can build up and cause the tube to fail. A round tube has no corners and distributes all the stress over the entire surface.
Square might look cool but round tubes have been in style for a hundred years or more, probably for a good reason.
Just my opinion,
Jim Henderson
Old Oct 23, 2006 | 09:57 PM
1973F250CREW's Avatar
1973F250CREW
The stresses can be calculated using the following formula:
Stress Allowable = Tc/J
T = Torque (in-lbs).. or ft-lbs * 12.
J (polar moment of inertia)
-for a round tube, J=Jhollow = pie (ro^4 – ri^4 ) / 2
-for a square tube, J=Jhollow = J outer - J inner = (1/12 b*h(b^2-h^2)) outer - (1/12 b*h(b^2-h^2)) inner.
c = 1/2 of the outer tube size
But you're right, round is better for torsion (twisting). Square is better for structural bending (such as a frame).
Old Oct 24, 2006 | 11:11 AM
loudfords's Avatar
loudfords
A lot of farm equipment uses square tubing on PTO shafts to get the slip joint without splines. All the same, you would be better off getting your existing driveshaft modified.
95F150SuperCab
May 12, 2012 07:49 PM
quadzjr
Offroad & 4x4
Oct 24, 2006 10:51 PM
hotrrod69
Engine Swaps
Apr 10, 2006 07:19 PM
fordboy_52
Offroad & 4x4
15
Aug 2, 2005 06:05 PM
