Aerostar Ford Aerostar
95 running rough with a miss
Old Oct 22, 2006 | 02:09 PM
Dknydo's Avatar
Dknydo
Hi, I have been trying to figure out what is going on with my van. I have replaced all the plugs, wires, distributer cap, and the coil. I had to replace a new wire due to a faulty wire. I pulled a code of 114, intake air temp sensor out of self test range. What does this mean? And where would I find this sensor? This has been going on for abotu two months at least...
Thanks
Old Oct 22, 2006 | 02:29 PM
copper_90680's Avatar
copper_90680
Hi Dknydo:
Welsome to our FTE forum
The Intake Air Temperature Sensor is on the intake manifold itself. It has a two-wire connector on top and is located near the middle of the intake manifold, about halfway back on the driver's side. It should cost less than $20 at the local autopart stores.
Old Oct 22, 2006 | 03:35 PM
Dknydo's Avatar
Dknydo
Could this be causing my erratic miss problem? It seems to only miss when its warm. Any idea?
Old Oct 22, 2006 | 03:39 PM
96_4wdr's Avatar
96_4wdr
yes, faulty IAT sensor will cause wrong air temp info to be sent to PCM/ECU which calculates the correct air/fuel mix and thus the amount of fuel to inject based upon air temp....colder dense air=more fuel....hotter less dense air=less fuel
too lean mix=miss
too rich mix=miss
trying to maintain 14.7:1 ideal ratio in op. temp hot op. mode
cold start open loop operation does not use IAT sensor to set fuel injection amount....PCM uses fixed data table which manuf. programs in based upon engine, yr, model and equip...
PCM uses input from ECT sensor to switch from cold start/driveaway mode to op. temp hot temp. mode
Ford Fuel Injection click
you may have other problems also, but fix this one first
engine will NOT run correctly with faulty IAT
disconnect neg. batt. lead to work on any sensor....also clears KAM PCM memory of learned op. parameters from defective sensors and returns to factory defaults....takes 5>10 miles drive to relearn per your driving style
Old Oct 22, 2006 | 04:27 PM
Dknydo's Avatar
Dknydo
Thanks for your help,,,I will try and replace that, and we will see how that does....
Thanks again
Old Oct 22, 2006 | 05:18 PM
Bear River's Avatar
Bear River
Former ******
You say you replaced the plugs, wires, cap and rotor. What brand parts did you use. I think that it is quite likely that brand could be involved. Since you did get that code, I would treat that first, but if it doesn't clear up, let us know and we will try to point you in the right direction. Did you pull the code with the vehicle fully warmed up?
Lsvare
Sep 11, 2015 11:43 PM
wpwilburt791
2004 - 2008 F150
Sep 18, 2014 10:59 PM
Firefighter 1406
Feb 25, 2014 07:08 AM
gairforce1
Sep 22, 2011 09:37 PM
velcro7279
Jun 6, 2011 06:51 AM
